Aftermarket Amp Install Issues
I tried doing my install last night following this how-to and I've had a few hang ups. Ive got power, but no sound.
1. There is 4 harnesses that plug into the factory amp. Starting from the side closest to the front of the car: a small one with 4 wires, a bigger one with about 9 wires, a skinny one with smaller gauge wires that seems irrelevant, and then another big one with about 9 or 10 wires. Which is the correct harness to tap into for the front woofers and factory sub? This is non-ML btw.
2. I used the same Scosche LOC from Wal-Mart thats featured in the how-to. Did you have to mess with any of the gains or adjustments on that?
3. My amp always stays on so obviously I tapped into the wrong power lead for the remote wire. I was assuming it was the orange wire on that first harness with 4 wires but I guess this isn't the case?
Any help would be greatly appreciated! I was up till 2:30am last night trying to get this done only to have nothing to show for it. Thanks!
There was a post somewhere here that said the color of the 4 wires to tap into on the non-ML amp. All 4 wires are on the same harness. If I recall correctly, It was the second one with 9 wires. I could be wrong though.
Today, I will not be home until late. If you want, send me a PM and you can call me tomorrow after 5 and I can take a look for you and tell you what wires I spliced into and which harness.
I spliced the remote wire from a fuse box under the glove box.
if you are using tap-in's for bigger wires say like 12 or 14 gauge, it wont work cause its not really splicing through the wire to tap-in. since the skinny orange wire is so skinny u need a 16 or 18 gauge tap-in
Raju
12-14-10 11:03 AM
eerrrrr
07-26-07 01:04 PM
DroppedGS
12-15-05 07:33 PM
