Work Varianza T1s Tire Question
Old 03-24-08, 06:08 PM
radicalrev
radicalrev's Avatar
Default Work Varianza T1s Tire Question
Guys need some help!!
Going to run Work Varianza Front 20x9 offset 36 and Rear 20x10 offset 40...
gonna need some stretch tires for the front...but how wide should i go? 225 /30/20 or 235/30/20?
I tried on a 245/30/20 but it was over the fender tad too much...how stretch will the 9 inch width look using 225 or 235??
The rear fit just nice with 265/30/20 but will 275/30/20 do just fine??
I will plan to lower the car with H&R springs...
if any1 of you running stretch tires, please do advice or post your setup....thanks!!
Old 03-24-08, 06:17 PM
Signal_jp
Signal_jp's Avatar
your a sav for stretching a 30 series.
you could run a 225/30 and a 265/30 if you plan on lowering.
Old 03-24-08, 06:19 PM
radicalrev
radicalrev's Avatar
thanks signal..i am just about to see your post...i heard u have stretched tires too....
btw wads SAV?
Old 03-24-08, 06:53 PM
llamaboiz
llamaboiz's Avatar
hehe, im running a a pretty good stretch on 19"s just short of the extreme, 275 isnt 'stretch'
Old 03-24-08, 07:15 PM
radicalrev
radicalrev's Avatar
not the rear...i mean stretch for the front.... lol... since you have same 9" and pretty much same offset...do u have to go 225/30 or 225/35 is possible? so many potty holes here in LA..
for the rear...should i got 245 or 255? since i am going stretch on the front...wouldnt be weird if dun stretch it at the rear??
Old 03-24-08, 10:25 PM
Signal_jp
Signal_jp's Avatar
SAV = savage
im just saying your stretching a 30 profile. 30 series are like rubber bands already but stretching it is nuts. stretching a 35 series tire is almost pushing it but a 30 is a little crazy.
Old 03-24-08, 10:32 PM
radicalrev
radicalrev's Avatar
but will 35 rub?? i know llama has 225 and he has 9" width but i don't know if he is running 30 or 35....
Old 03-24-08, 10:38 PM
Signal_jp
Signal_jp's Avatar
a 35 has a higher chance of rubbing than a 30.
llama has 19's and you have 20's. of course he would run a 35 cause he has a smaller rim.
Old 03-24-08, 10:41 PM
D&G
D&G's Avatar
I wouldn't go 35series tires. I would go with 235/30/20 tires up front.
Old 03-24-08, 10:42 PM
llamaboiz
llamaboiz's Avatar
sorry, was busy... i have a life (looking for anime to dl, chating on aim and irc, playing video games)
Ok, i run 35 series tires, thing about the stretch thou is that not all tires can do it and hold the seal.
Old 03-24-08, 10:47 PM
radicalrev
radicalrev's Avatar
dang...so confused now...i dun even know what tires to put for the rear since i'm stretching the front...
option 1: 225/35/20 Front
or
option 2: 235/30/20 Front
for the rear, if i want to have a stretch look like the fronts, what tire sizes should i go for?
thanks guys!
Old 03-24-08, 11:00 PM
llamaboiz
llamaboiz's Avatar
ok... i see your difficulty, thing is, i cant really say as i run 19"s and have no xp with 20" stretch. BUT all i can say is, your rear offset is alittle conservative so im sure a 265 would fit, BUT alot depends on your drop also... sorry not much help i can offer EXCEPT:
*bump to the top*
Old 03-24-08, 11:04 PM
radicalrev
radicalrev's Avatar
hahaha..thanks llama...yeah i guess the rear tire would be 265...but the thing is that there is no 265/30 with Falken 452...ugh...only 255.....but 255 is meant for 8.5"-9.5" so i guess that wont work either...so left with 275/30? will it still has the stretched look?
edit: NVM...i guess the rear you can do 255/30/20...the only closest setup to mine is Genki, who also have the T1s 20x10 +40 and he runs 255/30/20 rear and 225/30/20 with front 20x8.5 +38...since mine is 20x9...i guess 235/30/20 would fit just nice...?? lol...
Old 03-25-08, 12:18 AM
llamaboiz
llamaboiz's Avatar
well... as for widths, i have 225's on my 9" and 245's on my 10", now this is stretch . BUT someone here... i forget who went even more extreme 215's/235's... if i remember correctly
Old 03-25-08, 12:28 AM
radicalrev
radicalrev's Avatar
lol...your's seemed already pretty stretch on the rear...i guess 255 would look stretched enough...the front i got a great deal on a pair of toyo t1r but 235/30/20....so i dunno if i shud go for 235 or 225...danggg..
Quick Reply: Work Varianza T1s Tire Question
