View Poll Results: What % of the time do you guys use PWR ECT?
100%
25
13.81%
75%
4.97%
50%
18
9.94%
25%
59
32.60%
NEVER
70
38.67%
Voters: 181. You may not vote on this poll
Old 03-26-08 | 03:54 PM
  #31
y2ks2k's Avatar
y2ks2k
CL Folding Freak
CL Folding 1M
Originally Posted by phatboyc
I haven't used it since finding out it gives worst 1/4 mile time. Shifting gears sooner at the expense of acceleration, I'll pass.
From what I understand and experience of PWR mode, it wouldn’t effect a quarter mile at all or any way. I run pwr most the time and there’s a major difference between it and standard. Mostly that when you *brake* or *slow down* it keeps the RPM's up longer. For example, you slap the brake pedal pretty hard and with pwr mode it will shift down and bring the RPM's up sooner.
I would suspect if people are saying pwr affects actual dragging, the effect they are feeling has nothing to do with it being set to “pwr”.
So in effect, if you were dragging a quarter with pwr on or off in which you went from 0 to 100 and then slammed the brakes to 50 and then back up to 100, pwr mode would perform better.
More so, if you are on an actual track with lots of turns and fast acceleration changes, pwr mode would be keeping you in lower gears and higher rpm's like you would be with a manual. It would perform much better.
Old 03-26-08 | 03:57 PM
  #32
Memout's Avatar
Memout
I always thought pwr mode used up less gas than normal or snow mode...that's why I use it..
correct me if i'm wrong
Old 03-26-08 | 04:00 PM
  #33
y2ks2k's Avatar
y2ks2k
CL Folding Freak
CL Folding 1M
Ive run tests with my pwr mode on and off with full tanks of gas with no real difference in my mpg.
Old 03-26-08 | 05:32 PM
  #34
VTLexus's Avatar
VTLexus
do you do primarily highway driving in power mode? There is a clear difference in MPG - it is lower when you use PWR.
Anyone else have an opinion on 0-60 or 1/4 mile times with and without PWR? I would imagine it wouldn't make a difference, or PWR is faster, but definitely not slower. i haven't tested it yet.
Old 03-26-08 | 05:38 PM
  #35
oblivionis's Avatar
oblivionis
The only times I don't use it is in the winter time and at the dragstrip.
Old 03-26-08 | 05:50 PM
  #36
kickin8's Avatar
kickin8
2IS/2RX/4RX
my car doesnt have it..... it only got snow mode.....
that means it's on 100%?
Old 03-26-08 | 07:15 PM
  #37
meefer's Avatar
meefer
I drive an IS250, PWR isn't in my car's vocab.
Old 03-27-08 | 01:18 AM
  #38
Hartawan's Avatar
Hartawan
Former Vendor
1%, I always forget it's there.
Old 03-27-08 | 04:33 PM
  #39
GordoNx3o9's Avatar
GordoNx3o9
Originally Posted by Joe Z
With the Manual 6 Speed.. you control ALL of your shifts...
That I understand, but when PWR mode with an automatic, it makes the throttle more sensitive as well.
Old 03-27-08 | 05:49 PM
  #40
kindred6ul's Avatar
kindred6ul
Sex Panther...Works 60% of the time....All the time...
Old 03-27-08 | 11:29 PM
  #41
L-FIN-S's Avatar
L-FIN-S
I've had my 350 a few months now, never really had a need for the pwr button. If I need more pwr I just MASH the gas pedal!
Old 03-27-08 | 11:55 PM
  #42
dereks's Avatar
dereks
I used it when I want to jet off the line . It seems more responsive to less pedal input, but that could be my imagination. I find it increases throttle response, and seems to do engine breaking, as others have mentioned.
I was playing around with the paddle shifters tonight on the way home. Letting the engine rev up a bit. I don't really like the lag between shifts, but it seemed after a bit of use I was adjusting to it....
Probably use it a total of about 10% of the time. I do not used it enough to gage gas mileage. Which is about 23mpg on a tank right now, on my ~500mi/week commute.
Old 03-27-08 | 11:56 PM
  #43
XprincoX's Avatar
XprincoX
i practically never use mine. I've used it probably a hand full of times when merging onto the freeway.
Old 03-28-08 | 12:52 AM
  #44
wolverine's Avatar
wolverine
all the time
Old 03-28-08 | 10:05 AM
  #45
phatboyc's Avatar
phatboyc
I wont dispute it here since this isn't the right thread for it. But it has been proven that better 1/4 mile time are achievable in normal.
Gernby spitting shift point knowledge, use Normal!
