Help needed: Center console cup holder door
The little door/flap in the center console that hides the center cup holder is not opening completely, its supposed to do a 45 degrees movement, but its only doing like 30. I noticed that there is a compartment were the door hides when its opened and maybe something got stuck in there (a coin maybe), but I can’t reach inside of that part.
I tried to remove that part of the console, but it’s attached with the armrest. Anybody have a diagram on how to disassemble this part of the console?
Thanks,
Thanks,
Thanks,
Thanks,
Did you mean that it's supposed to do a 90-degree movement, rather than a 45-degree?
Thanks,
Thanks,
Also, you could use a high powered wet vac andd succk the coin out that could be contributing to the door not opening fully. It is a quick trick that will save you the time of removing the consol. As the vacumn is on, I would wiggle the door a bit to free up the coin and promote the release.
