Um... My Paddle Shifter Is Not Working...
well to be honest, i either dont know how to use the paddle shifter, or it is just broken... it doesnt downshift when u press it.. and it doesnt upshift when u press it either... it kinda changes for itself... and the my car shows 2 different gears at the same time... so the one above the S light... shows for example 5, but the one in the display monitor shows 4.. ... except that... one other thing i dont get is that when my car is in the S... but its not moviing... when i up shift or downshift the ****... in the display picture it adds dots infornt of my present Gear (which is 1) ... can somebody try to explain it to me... becuse i looked in the manual... and there wasnt no straight up answer... and one other thing is that... i have to race my friend's RX8... and i kinda need to figure out how the paddle shifter works before i do that... other wise it would be kinda embarressing... btw, what is the best way to drag race?? should i just turn everything off, put the car in ECT PWR... and put the car in S???
ok one thing, explaining how the paddle works i'll leave to someone else who is more eloquent than me. if your going to race someone in a straight line leave it in auto. you cant shift faster than the auto does. if you notice from bracket racing to NHRA top fuel cars their all automatics (in a sense).
exactly what llamaboiz said. leave it in auto, ect pwr doesnt actually add power to your vehicle, its meant for situations such as when youre going up a hill and wanna keep the power instead of downshifting and losing it (in a sense)
as for paddle shifters, they arent fully manual. think of it this way, when you upshift, it limits your vehicle so it cant go past that gear, but the car will still shift normally up until it hits that gear, where itll stop until you upshift again.
when downshifting, itll have the same idea. it will lower the gear if youre in a higher one, but lets say youre in 2nd gear and you downshift from 5th to 4th. itll still stay in 2nd gear, because that "S" gear is acting as a limit for your vehicles gears. the vehicle will also prevent you from downshifting too low to avoid any troubles that may occur.
for your displays, the "S" display shows what gear you have set for the vehicle. in your center mini-display, it shows what gear the vehicle is actually in. basically, lets say youre stopped and youre driving in "S" mode. if you upshift to gear 3, itll show "3" in your "S" display, but your actual gear will be in "1".
hope this helps answer your questions!
ps. the dots represent the gears your vehicle isnt in
ok... im kinda following this... but i think i should definetly try this out before racing her... just to save the embarressment of the car shifting to 2nd gear on 20km... lol... and u know how u said leave it in auto... so just put it in D and stop beside her and just slam the throttle as hard as i can???? no S paddling no upshifting by myself??? none of that??? wow... that sounds kinda really easy.. lol
however... do u guyz think which one would win??? RX-8 Auto - vs is250 Auto... techniqually the IS should win becuse the ~20 extra hp... right??
i think we have the same hp.. but i have more torque... and her car is lighter than mine by 100KG... thats alot... i think i need to stand one car infront of her.. this is so embarressing... u know i should have bought a is350!!!
Super Moderator
The paddle shifter sets and the big number above the "S" shows the maximum gear the car can automatically select. The one in the info display shows the gear that the car is actually in.
If you select a maximum gear that is lower than the one you are currently in, it should downshift immediately. (Or beep at you if downshifting would cause engine damage)
There is no way to compel an upshift.
