Another Offset problem
Ok. I bought these rims that are the R2 DTR-3 Black with chrome lip rims.
I have a problem though. I have an IS350 and the fronts don't seem to clear the brakes? The front rims are 19x8.5 +35 and the rears are 19x9.5 +40. What spacers will I need to make the rims look flush with my IS 350?
ANY help on this will be appreciated
thanx.
On a 9.5 it won't be totally flush but it'd be close, a small spacer could be used, but maybe not even needed if you don't stretch the tire any.
Edit: What Llama said, I was just reading the flushness portion with concern of a drop.
Last edited by Zanorath; 04-03-08 at 09:41 PM. Reason: Because I didn't read the actual question
The mooncakes you bought arent R disk or High disk...
thats why they wont clear the brakes... its not the offset but the 'face' of the mooncake itself. As for the spacers for a flush look, what drop are you running/tiresize?
the front: 19X8.5 with 245/35
the back: 19X9.5 with 270/30
the car is lowered, I'd say, approx 1-1.5 inches.
I guess I'd have to use the spacers 'cause the brakes won't clear
i had to so spacers on the front only to clear my BBK...5mm is what you need. i dont see any issues so far but 235/35 will work. i get slight rub occasionally when i give it a full turn. sounds worse then it is. i am going to heat the corner it touches this weekend and give it a push.
