static noise using iPod+AUX+12V
I just bought iPod iCharger from Amazon: http://www.amazon.com/gp/product/B00015GYTU
I tried it today just to find that when iPod is connected through AUX and charged from 12V outlet, there is quite annoying background static noise. It only there when iPod is plugged to 12V. When it works from battery (still connected to AUX) there is no noise at all. Should I try another charger? Is it a common problem when using 12V outlet? Thanks.
Ground loop problem
happens when two electrical components share the same ground (which the 12V plug and aux input do share).
If you don't charge your MP3 player while playing you won't have this problem, or vice versa, just charging won't cause it)
http://www.epanorama.net/documents/groundloop/
I believe there's a TSIB for this matter... speak to your dealer!
There is a TSIB out for that noise.... Had it done on my IS works great
https://www.clublexus.com/forums/sho...ght=tsib+radio
Ground loop problem
I've seen a few folks say it was not fixed for 08s... but I haven't had this problem with my 08 using my ipod with my Belkin car kit (which both charges and provides a 3.5" out from dock to AUX)... I haven't listened more than a dozen or so hours total but I'd think it would've been obvious from the way folks describe it.
12jimmyjam
ES - 5th Gen (2007-2012)
12-10-15 02:24 PM
