Which bulbs for yellow fogs??
I bought a Yellow set on ebay with the same OEM 55 wattage and was not happy with the weak light output. Other CL Members like the Nokya like llamaboiz, but I would consider an HID kit. I have purchased the Yellow fog vinyl on top of the yellow bulbs. In a month or two, I am doing a Yellow HID kit in order to have clear lenses again with a fancier/brighter look. It is something to consider. Never install a higher wattage bulb, it will melt the harness over time and some members have experienced this unfortunately.
if it is none HID i would go Luminics or Nokya...
Nokya are supposedly brighter and better
but i heard they turn to burn wiring harnesses if you don't have an aftermarket harness because of the higher output.
had luminics and no problems but go HID if you can!
adamz28
03-22-12 10:15 AM
