No More Semi Annaline Leather in 2008's
#76
excuse my ignorance, but WTH is semi-annaline leather anyway. my 07 rwd has the softest leather i've ever had in a car and i can't imagine it being any softer without giving up something in the durability category.
#77
Semi-aniline leather is very lightly clearcoated, and is typically softer than typical coated leather. It is subject to wear quicker and easier than coasted leather.
Protected aniline leather (what most of us actually have in cars) are clearcoated, and are the best for wear, color consistency, etc.
For those of you buying expensive leather conditioners, you're wasting your time if you have protected aniline leather. I use Zaino leather products regardless because I like the scent, but protected leather has a poly clearcoat on it, and you can protect it with the same stuff you use on your dash (really!). Leather care products WILL NOT soak into clearcoated leather, so if you leave a leather care product on your clearcoated leather, buff it off, and then convince yourself that the seat "really soaked that up", you're suffering from a placebo effect.
Semi-aniline leather seats will benefit from proper leather cleaning and conditioning, and they need it much more often than true clearcoated seats. Semi-analine leather is associated with top end luxury cars, but it can be a real PIA to maintain over time. I have semi-aliline leather on the couch in my home, and it's easy to tell because some color comes off on the cloth when I clean and condition the leather (similar to what happens when you polish a car that isn't clearcoated).
Hope this helps.
#78
Analine finish is when leather is soaked in a clear dye. It is basically a finish that will help to make the leather more cleanable. Remember that leather is skin and if left untreated it will absorb everything. Semi-analine leather finish has a smaller amount of dye used on it. It gives it a little bit of protection, but not as much as a full analine finish does.
Doesn't really say anything about the softness of the leather, though. May be that the IS250's had the semi-analine leather because the vehicle is more likely to be driven in bad weather conditions where the leather might pick up more dirt, road salt, etc. Just a guess on my part, though.
#79
This is from the Associated Content website. It pertains to leather furniture, but I suppose it would apply to car leather as well:
Aniline --> Semi-Aniline --> Protected/Coated Aniline
Pure aniline leather is uncoated, and porous. It will stain if you spill something on it.
#80
I know you're just quoting a website, but I think it's important to mention that Aniline leather isn't coated. From least protected to fully protected:
Seems like you are much more knowledgeable on the matter and I defer to you. Plus, what you're saying makes a lot more sense, anyways!
#81
[U]
I use Zaino conditioner for the same reasons.
Pour a drop of water on your seat.If it doesn't get absorded into the leather,the leather is vinyl coated.Most leathers today are vinyl coated.
I get a kick out of posts that say the leather gets so soft using XXXX brand conditioner.If the leather is coated....the conditioner ain't absorbin' in.
#84
Aniline leather is simply dyed with pigment added for consistency in color, and shows imperfections in the hide, will fade out eventually in the sun, and wears fairly easily - not a good leather for cars, to say the least.
Hope this helps.
Hope this helps.
#86
That is a great post!!! Thanks for the input and now we can all sleep easy!!!
#88
All is an *ALL* 2IS or All as in All 2IS with perforated leather seats only?
#90
