View Poll Results: Fog light color on a Breakwater Blue IS?
Keep it stock.
15.28%
Racing Yellow.
34
47.22%
Crystal blue.
20
27.78%
Other (please explain).
9.72%
Voters: 72. You may not vote on this poll
What color Fog Lights with my car?
Old 04-15-08, 03:29 PM
kiddolay
kiddolay's Avatar
Smile
I say go with HID because:
1.) I have read that changing the blub caused fire (not good eh). But that was the one case I've read. So make sure to get the right wattage on the blub. And they do run hotter at 55W output.
2.) HIDs run at 35W, have a longer lifetime rating, and in the club venders section, there is a thread for mobileHIDs with 36 month warranty on blub and ballasts! (I am not commercializing and received no benefits, just giving a review based on what I've purchased).
The difference is steep and the installation has to be of patience. Either way, you can't go wrong with yellow.
Old 04-15-08, 07:04 PM
hapaboy
hapaboy's Avatar
you will see my 3000K fogs this weekend, if you are there.
Old 04-15-08, 07:20 PM
llamaboiz
llamaboiz's Avatar
only thing i have against yellow hids... they look green when you look at them IRL... is that cuz its new and needs to be broken in? say after 3 months do they still look green?
Old 04-15-08, 08:23 PM
Zanorath
Zanorath's Avatar
I thought that was just for the warmup time when turning the HID's on. Of all the video's I've seen they start green then change to yellow. Also, all 3000k kits are not made as the same color, XenonDepot's 3000k bulb is yellow itself, not clear like the other color temps.
Old 04-16-08, 12:14 PM
Brian231
Brian231's Avatar
If possible, can you post some day and night pics? I am sure there would be a lot of members that would love to see them.
Old 04-17-08, 03:06 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Thank you for your detailed insight.
Old 04-17-08, 04:10 PM
Zinda
Zinda's Avatar
I wonder what sort of fogs would look good on a SMG.
Old 07-16-08, 12:10 PM
XtrabOoSt
XtrabOoSt's Avatar
Xenon Pink...*
Old 07-18-08, 03:49 AM
808Lexy
808Lexy's Avatar
hows about first you put on some yellow overlays, then you take it out. put some yellow bulbs then switch it to blue bulbs. after, you put some hids 3000k then put 6000k or whatever. then finally you go back to stock.
Old 07-23-08, 09:37 PM
hapaboy
hapaboy's Avatar
DAYTIME: right fogs 3000K left fogs 6000K
NIGHTTIME: right hot cocoa vending machine left 3000K fogs
Old 07-24-08, 06:05 AM
passnu2
passnu2's Avatar
Left looks much better! 6K "or" 5K look the best. They also offer the light output that the IS should have had from OEM...
Old 07-24-08, 08:11 AM
andyboy
andyboy's Avatar
other...I like the white look
Old 07-24-08, 09:46 AM
venZon
venZon's Avatar
Question... What's with Yellow Fogs and Lexus? We're Yellow Fogs OEM in Japan or something?
I'm a lexus noob
Old 07-24-08, 12:22 PM
hapaboy
hapaboy's Avatar
yellow does not reflect off fog as much as white light. meaning no glare.
yellow is also used in ALMS series racing cars i also think some rally cars use yellow.
Old 07-24-08, 12:36 PM
venZon
venZon's Avatar
I know yellow fogs produce beter light for fog. But it seem like a lot of LEXUS guys run them. Is there any reason why?
Quick Reply: What color Fog Lights with my car?
