Installed a USA SPEC IPOD interface yesterday
Old 06-15-08, 09:05 PM
  #46
crazy_vag
crazy_vag's Avatar
Originally Posted by tbaker4
Thanks for the word - I will tell my installer.
I guess (looking at other posts) that unless I start cutting wires, that the Artist/album etc. menus become unusable when the car is moving?
t
Yep. It's well worth the effort though. Not too different from diffusing a bomb.
Old 07-04-08, 08:56 AM
  #47
NAK
NAK's Avatar
Default here some proof of USA-SPEC PA-20 real "audio quality"
Unit 1 - USA-SPEC PA-20
Car: Lexus IS350 with Mark Levinson
Connection: 12-pin CD/SAT port
Input signal 1kHz, 0 db (channel 2, purple line)
Signal Source iPod Video 5.5Gen
Output signal - inverted output used for better understanding (channel 1, yellow "line")
As you can see output signal modulated (distorted)
Attached Thumbnails Installed a USA SPEC IPOD interface yesterday-scrn0042.png
Old 07-04-08, 09:00 AM
  #48
NAK
NAK's Avatar
better "Zoom"
Attached Thumbnails Installed a USA SPEC IPOD interface yesterday-scrn0043.png
Old 07-04-08, 09:07 AM
  #49
NAK
NAK's Avatar
now CH1 (yellow) - Left output , CH2 (purple) - Right output
at 3kHz. I do not know how we can talk about THD here
Attached Thumbnails Installed a USA SPEC IPOD interface yesterday-scrn0050.png
Old 07-04-08, 09:12 AM
  #50
NAK
NAK's Avatar
"Frequency Response"
Input signal (CH2 purple - 440Hz square wave)
Output signal (CH1 yellow)
Not even close to be good!
Attached Thumbnails Installed a USA SPEC IPOD interface yesterday-scrn0053.png
Old 07-04-08, 09:17 AM
  #51
NAK
NAK's Avatar
Now different USA-SPEC PA-20 unit...
Difference in amplification between left and right channels are more than visible.
This one was pretty close to burn my amplifier
Attached Thumbnails Installed a USA SPEC IPOD interface yesterday-scrn0058.png
Old 07-04-08, 09:18 AM
  #52
NAK
NAK's Avatar
to be continued....
Old 07-04-08, 11:34 AM
  #53
kyrsplat
kyrsplat's Avatar
So I take it the discrepancy between purple and yellow lines shows the distortion caused by the USA Spec adapter?
Old 07-19-08, 07:43 PM
  #54
i3urton
i3urton's Avatar
so this kit is also plug and play?
Old 07-19-08, 09:01 PM
  #55
NOVAGFC350
NOVAGFC350's Avatar
Yes, it is. It charged the ipod while its in use as well. Pretty much the same functionality as the OEM Lexus Ipod Adaptor kit, however this one use CD Changer emulator instead of SAT as for the OEM kit. In addition to this, you still be able to use/install the OEM SAT radio (Sirius or XM) adaptor kit along with it if you like.
Old 07-25-08, 08:21 PM
  #56
Quiverfull
Quiverfull's Avatar
So what is the bottom line? Is this unit decent or not?
Old 07-25-08, 09:12 PM
  #57
NOVAGFC350
NOVAGFC350's Avatar
Its working great as advertised I'm very pleased that I got it. Does that answer your question?
djrabbi
01-26-16 03:59 PM
SteKbierr
12-03-07 06:38 AM
Vjammin
12-15-05 04:34 PM
Quick Reply: Installed a USA SPEC IPOD interface yesterday
