Anyone know how to retrofit mirrors to come down when reverse?
Hi, I didn't know is350 didn't come standard that the mirrors come down when you put your car on reverse. If I knew, I would have bought that package.
But anyways, anyone know how to make the mirror come down? Maybe retro fitting it? Everytime I parallel park, I have to wait couple seconds to put the mirror down so I make sure that I scrape.
Tech Info Resource
Put the switch to either the left or the right mirror - take it off the center position - the mirrors will aim down automatically.
Anything is possible, but I think this would be a lot of work and expense. You'd have to get the right mirrors, and then wire it all in so when it goes into reverse the mirrors tilt down. I have the tilt down feature and rarely use it. Unless you are parallel parking it isn't worth much, imo.
I parallel everyday. San Francisco sucks ]=
lobux: I tried everything. My car doesn't have it. I think it is a package to have that isnt it? Part of luxury package maybe? but for sure if you have sports it has it.
Tech Info Resource
You may be right. There is a different part number for the mirror switch in the lux package. If you know someone with the lux package, you could swap the switch assemblies (very easy to do) and test if it fixes your problem. I bet it would. MSRP on the switch assembly is $136.10. It's a tad pricey to gamble on it working, but from what I've learned about the Body Electrical Network, it's very possible replacing this switch would add the functionality.
The power windows and the mirrors all connect to a network connection that tells the Body Electrical ECU what to do. Changing the switch will tell it to do something different - and very likely give you the down feature you want.
If I still lived in Cali, I'd test it with you, but I'm in Georgia now.
That would be pretty awesome, Someone test this and report back.
Although, I have a feeling that it would require something a little more. the same way that the 06's don't have plug-n-play door sills (even though the plug is there), I wouldn't be surprised if the function is "disabled" somewhere else (ie-the wire is a dead-end somewhere)
Let's hope that it does work. I think for $130, it would be worth it, as it may help those out that don't have a back-up camera (I've never been in an IS with the camera, but if it has a fish-eye lens I think you would see the curb a little)
With all the people on CL that work at a dealership, I would think that someone could easily get their hands on the switch and do a quick swap on their car or a new car.
(hint-hint)
edit: although, it looks like the tilt-down mirrors also have auto-dimming, which would mean that they are different mirrors all together. Therefore, might not be as easy as a switch.
Tech Info Resource
Eh. Sorry to get your hopes up like this. If you don't have the memory seat option, your mirror control is direct by wire. If you have the memory seat option, you have an ECU that talks to another ECU in each of the mirrors. So the determinant here is whether you have the memory seat function or not.
As a side note, all the circuitry for folding side mirrors is in the wiring diagrams on TIS. I've never looked at this before, but the documentation calls out everything for folding mirrors including a button on the mirror switch that would cause the mirrors to fold in. It would be interesting to find out if all the wires are actually there and all you'd need is the switch gear and the Euro/JDM spec mirrors to get the folding function to work.
Sorry about suggesting the switch being the simple fix. It isn't from what I can see on the wiring diagrams.
Tech Info Resource
