View Poll Results: Break-in Mileage
<500 miles
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
73
27.14%
500-1000 miles
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
135
50.19%
1000+ miles
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
61
22.68%
Voters: 269. You may not vote on this poll
Break-in period
Break-in periods with cars these days is carry over from cars 20 years and older. Tolerances have tightened up, materials and lubricants have gotten better etc... Brake break-in is another matter and still necessary, but most modern engines do not need a major break-in period.
Tech Info Resource
lobuxracer, maybe you can clarify your statement but, most good modern day pistons are forged, i.e. their grain structure is set during the forging process. In order to change the grain structure it will have to be practically molten and then re cooled, is this what you're saying? Also, aren't most pistons "cam ground", thus taking care of the expansion you allude to?
Pistons are not evenly heated. Their grain structure, even when forged, will undergo significant change as they are initially heated and cooled. This is precisely why I advocate a break-in process that gradually increases load while allowing a 5 minute cooldown period between load sessions. This way the pistons are not thermally shocked in a way that will cause them to lose the shape the manufacturer spent so much time and effort to achieve.
Used pistons require NO break-in, and rings can be broken in with a few short full throttle runs terminated by rapidly closing the throttle to pull oil up past the rings and help remove the metal shavings from initial ring wear.
Super Moderator
Tech Info Resource
Here's the full sized pic. It's from Kistler. They make all kinds of piezo-electric transducers; what interests me are their pressure transducers for engine development. The pic is a V-8 with a single turbo at full boost/full load.
No OEM uses forged pistons for a street car. They make too much noise on start up because their fit has to be looser than cast.
Don't quote me on this but that old 4.2 Jaguar 6L had forged pistons, for sure the new V8 has forged pistons. What made the Cosworth pistons produce more power, was it weight, shape,...?
Tech Info Resource
Choice of alloy. Where does Jaguar say they are using forged pistons? I can't find it in any of their marketing material.
I always figured break in periods was around 1,000 miles and brakes were 500 miles. I was also told that you need to do the first oil change at 1,000 miles too. Can you guys confirm this? Possibly due to the metal shavings?
Super Moderator
You aren't going to find anything approaching consensus about break in procedures and oil change intervals on this forum. There are many long threads in the archives debating the merits of various approaches.
I strongly doubt Jag was using forged pistons in any of its stock block V8's. That design is ancient.
There are some vehicles that have come from the factory with forged internals, but they're all low production, high performance versions of cars where engine noise isn't an issue with buyers.
The new LS7 in the Vette is an example:
"Within the LS7 block, you'll find a forged-steel crankshaft, forged-steel main-bearing caps, titanium connecting rods, and forged pistons."
I just read online that their V8 (supercharged?) uses forged pistons, the 4.2 was along time ago and like I said don't quote me, but from what I remember it may have been forged.
The dealer mentioned oil changes done at every 5,000 miles. Standard on all Toyota vehicles. But that 621 miles of break in period sounds good. I have about 450 miles to go. I'll get to it in no time. Commute too much...
