illuminated scuff plate
Hey all,
I have an 08 is250 AWD, and i was wondering about ISPs. I've done some research on the boards but can't find any good info about what to order, how to install, etc. Could anyone who did this mod point me in the right direction?
Thanks
Thanks
https://www.clublexus.com/forums/sho...d.php?t=203289
its really easy to do. Its plug an play. this thread should help you out!
You can order them from one of our vendors or just about anywhere!
Mike
Mike
You can order the older style with blue 'Lexus', or the new for '08 white 'Lexus'. Your choice. It is a plug and play item for 07 and 08, takes all of 5 minutes. No skill required.
Sewell Lexus is good vendor, use CL911M discount code for your 10% savings.
hey be careful because some of our cars depending on the package might have the plug and play set up, but no electric is flowing through the wires. For my car i got it base with premium and i had to tap wires to get electric flowing.
Will be able to help you out!
Do you know if the Lexus nameplate has the color, or is the bulb blue or white? My 07 RX350 has an off-white color and I wanted to determine if I have to purchase a blue Lexus scuff plate or if I can change the bulb to a blue LED. Do you know if the bulb can be changed?
PhilipMSPT
07-24-08 12:28 PM
TommyT
01-31-08 08:54 PM
