Gas Mileage Observation
For the first 2-2.5 months I had my IS350, i was averaging about 18-19 MPG. Since about mid-March I have been getting 21-22 mpg. I first thought it was the gas station b/c I was using Sunoco at first and then switched to Shell. I went back to Sunoco on my last fillup, and I still have the improved mpg. My driving roads and style are nearly constant.
My two ideas are:
1) mpg was lower in the winter. I read that gas can burn quicker in cold weather due to the additives in gasoline.
2) car took a few months to break in, and now i get better gas mileage.
anyone notice anything similar or have an answer?
My two ideas are:
Tech Info Resource
1. It's warmer.
2. The fuel is "summer" mix, not winter, so it has less oxygen and more HCx.
Assuming no change in driving style due to nutty gas pricing, then both theories are valid.
I've seen a bit of an increase in mpg since the 20K mark.
Through year 1 of ownership, mileage was better in the summer.
My 350 drinks gas (18mpg) My 335Coup gets like 16mpg and lets not talk about he 4.8 x5, talk about 10-12mpg.
I don't even look at the window sticker any more for MPG whats the point. You can afford the car you can afford the gas, why worry your self over 1 or 2 miles more. if you look at it its really an extra 30 miles you get out of a tank of gas. Sorry i got bigger things to worry about then get 30 miles out of a tank of gas.!
^^ sux some people still have that mindset, thats why hummer is still in business
i've actually noticed the same thing recently and was going to look some stuff up, but i too had under 20 mpg for the first 20k miles, and now i'm getting 24mpg... i have changed my driving style somewhat with gas prices, but no where near enough to make a jump from 18 mpg to 24-25, but i never knew that there was a summer and winter gasoline, thats probably got something big to do with it =p
Do you know whats wierd?? I was getting 25-26 MPG average per tank here in Phoenix on my 250 RWD, i do the same driving everyday to work and back.. 50% city..50% highway... I had to disconnect the battery the other day installing my XM.. Now its been 2 weeks and im only getting 22 or 23 max mpg on the two tanks i went through, same driving style.. whats going on?? I know its getting a little warmer, so more AC use, but not that much different...
I've had my IS350 for a month and a half now and my MPG has gone from 19 to 23 when I filled up today. I'm in Louisiana, so I don't think that there is a sumer/winter blend for gas.
**My first post!**
**My first post!**
