Need input asap on 275/30/20 for rear please.
Old 05-07-08, 10:17 AM
RobzKar
RobzKar's Avatar
Default Need input asap on 275/30/20 for rear please.
with those having this tire setup on your 350 for the rear being lowered. Do you have any problems with rubbing issues. Input would be great please. thanks..
Old 05-07-08, 12:46 PM
javyLSU
2IS OG
javyLSU's Avatar
I'm running this size tire in the rear dropped on IS350 Eibachs. I haven't had any rubbing whatsoever. Some have said they needed to shave the inside of the rear fender, but I didn't even need to do that. Fits perfectly.
Javier
Old 05-07-08, 05:26 PM
RobzKar
RobzKar's Avatar
Javier
Thanks buddy. I wish more people with this setup chime in so I can get an idea if some do have problems. thanks again.
Old 05-07-08, 08:28 PM
sinister2c
sinister2c's Avatar
offsets man...all about offset. Theres room for 285/25/20 if the offsets right
Old 05-07-08, 09:32 PM
radicalrev
radicalrev's Avatar
yeap, all about offsets...but with 275/30/20 with a conservative offset, you should be fine...
Old 05-09-08, 12:35 AM
ISCjonny
ISCjonny's Avatar
not for me.. i have 19x9.5 +25... i was goin with a 265.. but it wouldnt work so i had to stretch on a 245.
Old 05-09-08, 12:40 AM
ISF_GG
ISF_GG's Avatar
I'm not lowered yet, but I'm running 275/30-20's on 20x10 rims in the rear, and I have plenty of room to allow for a drop without rubbing.
Old 01-05-09, 09:17 AM
juice14
juice14's Avatar
would a 275/35/19 fit on my rear if i have 19x9.5 wit a +37mm offset?
Oir will i rub??
Old 01-05-09, 09:21 AM
shadow191
shadow191's Avatar
At 9.5" and +37, you should be fine with a 275 tire.
Oir will i rub??
Old 01-05-09, 09:39 AM
BoOst3d
BoOst3d's Avatar
on a 9.5 u should run a 255 and with a +37 offset u should be fine
Old 01-05-09, 10:35 AM
juice14
juice14's Avatar
I had 265/30/19 and I hated the look. I drove them for 50 miles and asked for a refund. those only look good if you are slammed. and I only have eibachs.
this si why I just ordered 275/35/19 they will definitely cover the fender hole better. I know if there is rubbing, it should be minor because some guys have similar setups.
thanks
lexasgs400
07-31-10 06:40 PM
thomastan
03-24-09 05:46 PM
tomtsops
10-03-07 04:36 PM
tommyGS3
Wheels, Tires & Brakes Forum
12-15-05 08:02 PM
Quick Reply: Need input asap on 275/30/20 for rear please.
