Did I mess up my car? (by making a Lucas additive cocktail in my oil pan)
Old 05-15-08 | 01:14 PM
HighImStan's Avatar
HighImStan
Default Did I mess up my car? (by making a Lucas additive cocktail in my oil pan)
I just added Lucas Synthetic Oil Stabilizer in with Royal Purple 5w20 for my oil change. Is this a bad decision?
Old 05-15-08 | 01:15 PM
Eddiebx's Avatar
Eddiebx
well i havent heard grreat reivews on that lucas junk in general......and i honestly dont see the point in trying to make a great motor oil better?
Old 05-15-08 | 01:17 PM
mikeh555's Avatar
mikeh555
no you didnt mess it up ive been using that on every oil change since 10k an im now at 50k
Old 05-15-08 | 01:30 PM
EJC's Avatar
EJC
Default Lucas
Is this the same Lucas so well known for its' electrical systems?
You know company motto - "Home before dark"
Company nickname - Prince of Darkness
I'd pass on the additive
Old 05-15-08 | 03:37 PM
KrapWerdna's Avatar
KrapWerdna
HAHAH
when he said "did i F up my car", i thought he meant he added the "F-sport accesories" to his car. like he "F"ed up his car.
but IMO, synthetic oil for the 2is is not necessary. if you want to, its cool too. i just use regular oil for oil changes.
Old 05-15-08 | 04:07 PM
Drunkebuda's Avatar
Drunkebuda
But dont go back to regular after you used synthetic tho :P and no you are fine...i dont think adding extra stuff to royal purple will help anything its just like those octane boost lmao.
Old 05-15-08 | 05:48 PM
maxnix's Avatar
maxnix
Might want to read at www.bobistheoilguy.com
Why so light a weight of oil?
Old 05-15-08 | 06:04 PM
FiveOhNine's Avatar
FiveOhNine
Originally Posted by KrapWerdna
HAHAH
There's a vanity plate for you F-Sporters:
F'ed Up IS
Old 05-15-08 | 06:45 PM
sonyman's Avatar
sonyman
Why are you adding **** to your oil? Motor oil manufacturers spend millions of dollars to get the chemistry just right in their products. If adding an oil stabilizer helped don't you think they would have done it already? If you're so concerned get a better oil. Royal Purple is expensive junk anyway.
Old 05-15-08 | 07:27 PM
4U2eNv_8o8's Avatar
4U2eNv_8o8
HAHAH
Hahaha!!! That just made my day. When I thought the day wasn't going so great I seen this post.
**Yes I know this maybe off-topic, but I just had to comment on the "out-of-the-blue" comment. I wasn't really think I was gonna see this post in here.**
Old 05-15-08 | 08:23 PM
llamaboiz's Avatar
llamaboiz
no you didnt 'mess up', BUT~ i will agree with everyone else, you dont NEED to add lucas to RP since RP is good enough the way it is...
Old 05-16-08 | 01:33 AM
HighImStan's Avatar
HighImStan
Thanks for all the input! I'll just put in RP and nothing else extra for the next change.
Old 05-16-08 | 01:47 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
you just make the oil "thicker"....that means you are losing mpg.....
Old 05-16-08 | 05:17 AM
SebsIS350's Avatar
SebsIS350
also in some cases the lucas starts to foam, which is a real bad thing. check it out http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 05-16-08 | 06:33 AM
Lexmex's Avatar
Lexmex
Super Moderator
You really don't need that particular product. That is a good product from Lucas, but more so for large trucks and more powerful engines that get a really good benefit from it. However, as was mentioned above it won't hurt.
I can tell that I have known racers over the years who run Royal Purple and it always seems to run 'heavy.' If the car normally runs W30 they run W40, etc., so that 5W20 should run you just fine by itself. Only other kind of oil I know that is like this is my favorite, Castrol 0W30 which has the characteristics of a W40 oil.
How much of this stuff did you toss in their BTW?
