Dealer pushing to avoid using fully synthetic?
Hey all,
Called up the local Lexus dealership and asked if I could bring in my own oil for an oil change (currently I am at 19,600 miles). They said no problem.
I then told them I was planning on switching to fully synthetic. The service advisor, who I've dealt with a couple of times previously and have been happy with, said Lexus doesn't recommend using fully synthetic?
He said Lexus prefers the 5k mile interval with their standard oil (I had heard it's a synthetic blend?). Obviously this gets you in the door more fequently to drop some more money over the longer interval with fully synthetic. He did say the fully synthetic wouldn't damage the engine or anything, but that Lexus prefers the shorter interval.
If you did run that long (7-10k miles) on fully synthetic, wouldn't you just need to change the oil filter after 5k miles?
Should I just stick to my guns and go ahead with switching to fully synthetic? What is best for our engines?
Thanks for the help.
don't ever believe the stealership,,,,sounds like their oil is magical.. its just oil...ummm if u switch u need to keep it syn... i dont plan on switching over until 15k miles..
You can do the 5k oil change at the dealer if you want. Its a complimentary service. This is what I did then I switched to Mobil 1 and have used it since. Just as the other member stated you just need to stick with the synthetic oil once you make the change.
I have never changed the filter out prior to the change. It cant hurt but I dont think its necessary. There is a thread that was started where a few members have sent out oil samples, using synthetic oil, to see how the break down is over XX amount of miles. I personally have always run 15k miles off synthetic in every car I have owned. I am sure from what I recall from that post you can probably push it more depending on where you live and your driving habbits!
Good luck
Mike
Good luck
Mike
You can do the 5k oil change at the dealer if you want. Its a complimentary service. This is what I did then I switched to Mobil 1 and have used it since. Just as the other member stated you just need to stick with the synthetic oil once you make the change...... I personally have always run 15k miles off synthetic in every car I have owned. I am sure from what I recall from that post you can probably push it more depending on where you live and your driving habbits!
Good luck
Mike
Good luck
Mike
I am waiting to switch to Mobil one after my 15k comped service. I ran it in my 2gen and it was excellent in cold winter start-ups. I love Mobile 1. I also used the 15k interval Mobil 1 and changed every 6k.
Liquid Bra Champion
Toyota engines are notorious for sludge problems. People using synthetic are less likely to change oil @ the recommended 6 month/5K interval. So they're more likely to decline provide warranty if you do not follow their guidelines.
i used mobile full syn every 3k.. lol you guys saying it lasts longer then 5k?? my oils like pitch black at 3k and preety dirty at 2k (changed it 1k too early :X) maybe cause i need to stop flooring it... even so lets say i drive normally 15k?? thats kind of too longg.. i read in one of the threads you change your filter every 5k and oil at 10k.. when you chanage out your filter at 5k top off your oil?????
Some great FYI...instead on listing to dealership service advisor. Read a published fact and then form your own decision.
Ten Myths About Synthetic Lubrication
First Published in National Oil and Lube News by Ed Newman
It's a fact of life that behavior is strongly influenced by what people believe, whether true or not. Numerous examples from history bear this out. For example, sailors were once fearful of sailing outside the sight of land less they would fall off the edge of the world. In the early 19th century, the train was considered dangerous because it was believed that if you traveled faster than 25 miles per hour, you would be traveling too fast to breathe. At a later date, the New York Times warned that electric light may cause blindness. Microwave ovens, automobiles and airplanes have had equally vociferous opponents.
Looking back, it is easy to laugh at some of these things people so firmly believed. But these people were not stupid. They were simply misinformed. In many instances they had simply drawn conclusions before all the facts were in. How easy it is to make the same mistake today. In our own time, synthetic motor oils have been the object of many misconceptions held by the general public. Many people, including some mechanics who ought to know better, have been misled by persistent myths that need to be addressed.
PARAMETERS OF THE DEBATE
Synthetic lubricants are fuel efficient, extended life lubricants manufactured from select basestocks and special purpose additives. In contrast to petroleum oils which are pumped from the earth and refined, synthetics are custom-designed in the laboratory, with each phase of their molecular construction programmed to produce, in effect, the ideal lubricant.
In responding to objections most commonly raised against synthetics it is important to establish the parameters of the debate. When speaking of synthetic motor oils, this article is defending the synthetic lubricants which have been formulated to meet the performance standards set by the American Petroleum Institute (API). (The first such synthetic motor oil to meet these industry-accepted tests for defining engine oil properties and performance characteristics was AMSOIL 100% Synthetic 10W-40 in 1972.)
Many people with questions about synthetics haven't known where to turn to get correct information. Is it super oil or snake oil? Some enthusiasts will swear that synthetics are capable of raising your specialty car from the dead. On the other hand, the next fellow asserts that synthetics will send your beloved car to an early grave. Where's the truth in all this?
In an effort to set the record straight, we've assembled ten of the more persistent myths about synthetic motor oils to see how they stack up against the facts.
Myth #1: Synthetic motor oils damage seals.
Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
Myth #2: Synthetics are too thin to stay in the engine.
Untrue. In order for a lubricant to be classified in any SAE grade (10W-30, 10W-40, etc) it has to meet certain guidelines with regard to viscosity ("thickness").
For example, it makes no difference whether it is 10W-40 petroleum or 10W-40 synthetic, at -25 degrees centigrade (-13F) and 100 degrees centigrade (212 degrees F) that oil has to maintain a standardized viscosity or it can't be rated a 10W-40.
Myth #3: Synthetics cause cars to use more oil.
Untrue. Synthetic motor oils are intended to use in mechanically sound engines, that is, engines that don't leak. In such engines oil consumption will actually be reduced. First, because of the lower volatility of synlubes. Second, because of the better sealing characteristics between piston rings and cylinder walls. And finally, because of the superior oxidation stability (i.e. resistance of synthetics against reacting with oxygen at high temperatures.)
Myth #4: Synthetic lubricants are not compatible with petroleum.
Untrue. The synthesized hydrocarbons, polyalphaolefins, diesters and other materials that form the base stocks of high quality name brand synthetics are fully compatible with petroleum oils. In the old days, some companies used untested ingredients that were not compatible, causing quality synlubes to suffer a bum rap. Fortunately, those days are long gone.
Compatibility is something to keep in mind, however, whether using petroleum oils or synthetics. It is usually best to use the same oil for topping off that you have been running in the engine. That is, it is preferable to not mix your oils, even if it is Valvoline or Quaker State you are using. The reason is this: the functions of additives blended for specific characteristics can be offset when oils with different additive packages are put together. For optimal performance, it is better to use the same oil throughout.
Myth#5: Synthetic lubricants are not readily available.
Untrue. This may have been the case two decades ago when AMSOIL and Mobil1 were the only real choices, but today nearly every major oil company has added a synthetic product to their lines. This in itself is a testament to the value synthetics offer. But, beware, many of the other "syntheitcs" are not true PAO (Polyalphaolefin) syntheitcs (ie: Castrol Syntec, Penzoil, etc...) they are hydroisomerized petroleum oil or an ester based synthetic blend.
Myth #6: Synthetic lubricants produce sludge.
Untrue. In point of fact, synthetic motor oils are more sludge resistant than their petroleum counterparts, resisting the effects of high temperatures and oxidation. In the presence of high temperatures, two things happen. First, an oil's lighter ingredients boil off, making the oil thicker. Second, many of the complex chemicals found naturally in petroleum basestocks begin to react with each other, forming sludges, gums and varnishes. One result is a loss of fluidity at low temperatures, slowing the timely flow of oil to the engine for vital engine protection. Further negative effects of thickened oil include the restriction of oil flow to critical areas, greater wear and loss of fuel economy.
Because of their higher flash points, and their ability to withstand evaporation loss and oxidation, synthetics are much more resistant to sludge development.
Two other causes of sludge - ingested dirt and water dilution - can be a problem in any kind of oil, whether petroleum or synthetic. These are problems with the air filtration system and the cooling system resoectively, not the oil.
Myth #7: Synthetics can't be used with catalytic converters or oxygen sensors.
Untrue. There is no difference between synthetic and petroleum oils in regards to these components. Both synthetic and petroleum oils are similar compounds and neither si damaging to catalytic converters or oxygen sensors.
Myth #8: Synthetics void warranties.
Untrue. No major manufacturer of automobiles specifically bans the use of synthetic lubricants. In point of fact, increasing numbers of high performance cars are arriving on the showroom floors with synthetic motor oils as factory fill.
New vehicle warranties are based upon the use of oils meeting specific API Service Classifications (for example SG/CE). Synthetic lubricants which meet current API Service requirements are perfectly suited for use in any vehicle without affecting the validity of the new car warranty. In point of fact, in the over 25 years that AMSOIL Synthetic Lubricants have been used in extended service situations, over billions of miles of actual driving, these oils have not been faulted once for voiding an automaker's warranty.
Myth #9: Synthetics last forever.
Untrue. Although some experts feel that synthetic basestocks themselves can be used forever, it is well known that eventually the additives will falter and cause the oil to require changing. Moisture, fuel dilution and acids (the by-products of combustion) tend to use up additives in an oil, allowing degradation to occur.
However , by "topping off", additives can be replenished. Through good filtration and periodic oil analysis, synthetic motor oils protect an engine for lengths of time far beyond the capability of non-synthetics.
Myth #10: Synthetics are too expensive.
Untrue. Tests and experience have proven that synthetics can greatly extend drain intervals, provide better fuel economy, reduce engine wear and enable vehicles to operate with greater reliability. All these elements combine to make synthetic engine oils more economical that conventional non-synthetics.
In Europe, synthetics have enjoyed increasing acceptance as car buyers look first to performance and long term value rather than initial price. As more sophisticated technology places greater demands on today's motor oils, we will no doubt see an increasing re-evaluation of oil buying habits in this country as well.
CONCLUSIONS
Since their inception, manufacturers of synthetic motor oils have sought to educate the public about the facts regarding synthetics, and the need for consumers to make their lubrication purchasing decisions based on quality rather than price. As was the case with microwave ovens or electric lights, a highly technological improvement must often overcome a fair amount of public skepticism and consumer inertia before it is embraced by the general population.
But the word is getting out as a growing number of motorists worldwide experience the benefits of synthetic lubrication. The wave of the future, in auto lubes, is well under way.
CONCLUSIONS
I switched to Mobil 1 5w30 at 5k. Even though my first oil change was free I brought my own oil in. It cost me about $35 for the oil at the store (5qt jug and 2 1qt bottles), it think it was about $10 a quart at the dealership. I take it to the dealership and they change the oil, check everything else and wash the car for $25. Not bad considering I pay $25 for a car wash anyway. You also get free drinks and cookies while you wait, and get to walk around the lot and look at cars (IS-F
). I know that full synthetic will go longer than 5k, but I don't like dealing with the reminder light, so I change it every 5K.
I have 16K on the car right now and before I go in for my next oil change I'm going to have an oil analysis done to make sure they are using my oil. If not there is going to be trouble!
Here is some good info on Mobil 1 that may be new to some of you.
http://www.ls1tech.com/forums/showth...hlight=mobil+1
Hope this helps.
Mike V
Hope this helps.
Mike V
Great Writeup jns350 ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I want to clarify on thing with
If a car has an oil leak the leak will get worse. The car may not use more oil, but you will be putting more oil in because the leak has gotten worse.
I changed my car's oil at 1500 miles, and switched to Mobil 1...
If a car has an oil leak the leak will get worse. The car may not use more oil, but you will be putting more oil in because the leak has gotten worse.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
FIX THE LEAK.
The incorrect answer would be- Use thicker, crappier, oil.
