draining engine coolant??
Does anyone know how to drain the engine coolant?
Or is there a DIY or any pictures of detailed steps anywhere on how to do it??
no im taking some out to add more water and some redline water wetter to keep my engine cool in this 100 degree weather.. Gnerby tried to tell me what to do.. but im not to quick i guess..
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
i tried using a turkey baster thingy.. with the tube and the ball at the end.. i got out about 18 ounces.. but i read that it hold 9.6 qt.. but the tank went from full to low.. so im a little confused
There should be a drain plug under the radiator and you night need a lift. I did a drain and fill with my gen 1 and used only the Toyota extended life coolant. Make sure to drain when the coolant is cold. You can also regulate the amount drained if you use a measuring device used in baking. Make sure the additive is Silicate and Phosphate free.
yea, Gnerby tol dme ther was a drain plud.. but im not sure where he told me it was.. bc if its on the the clear tank that says low and full on it.. theres no way that is 9.6 qt bc it was empty after i took out 18 ounces..
so i gues si have to drain from a different spot but i dunno where
Tech Info Resource
You've got to be kidding. What a waste of time and effort.
theres actually a very easy plug for draining and a hole right under neither it for putting something to catch the fluid.. its a little yellow **** you twist..
loxux.. apparently your mom never taught you if you dont have anything nice to say then dont say anythign at all
oh and it was about 5 min of time and effort..
Tech Info Resource
Your completely unfounded fear that it is somehow hotter in Texas than it is in the Mojave desert proving grounds Lexus/Toyota/Scion use is obviously causing you to want to change things "to run cooler." NOTHING could be worse for your engine. It is designed to run at a specific temperature, and nothing short of changing the thermostat will make this any different.
Not only have you reduced the amount of manufacturer installed coolant to no benefit, but you've added an unapproved chemical to the mix. If ANYTHING goes wrong - water pump seals fail, radiator manages to corrode, etc, etc, YOU will be footing the bill. Testing coolant is dead simple, and it's very easy to detect Water Wetter in your coolant. So basically you've taken your engine warranty at tossed it to the four winds for no good reason. Why would you want to do that? Oh, you're afraid it's hotter in Texas than it is in the Mojave. Right. Please.
I get irritated when people do ill-advised things out of fear with no basis in reality and with no data to prove the change you made has any positive effect.
There ARE reasons to change your coolant to water ratio, and there are reasons to run Water Wetter. None of those reasons apply to any ISx50 driven on the street today. Even the ones with superchargers running 5 psi of boost.
