rear tail light removal
anyone know how to remove the rear tail lights?
I want to paint them to give them the smoked look and would prefer to take them off and spray...
The local guys here want $300!!!!!
any ideas??..
thanks
any ideas??..
thanks
i recommend vinyl overlays check out www.aerotect.net they are a vendor here if you decide to sell the car later all you have to do is peel them off
There are 3 screws in each of the 4 pcs. You have to unscrew the bolts on them and unplug the harness and take out the bulbs.The trunk pcs are really easy to remove. The outer pcs are a lil tough just because after you take the bolts off, you have to give the tail light assembly a really good tug to get it out. If you're timid, you're not going to pull hard enough. I was able to get a reasonable grip on the right side and I tugged a couple of times and got it out fairly easily. The left side was little tougher. I couldn't really get a good grip and it took awhile to get it out. One other thing, you won't be able to unplug the harness or bulb on the trunk tail light pcs so when you go to pull the assembly out, just remember that there are wires and a bulb still attached.
If you have questions about removing the trunk lid cover or the hooks for the cargo net, just let me know.
For the outer pieces you need to remove the trunk liner first and you can use a small screw to remove the clips.
POZEST
06-01-17 04:19 PM
