Weird question regarding alternator.
Okay I am thinking of getting an high output alternator for my Lexus IS 220d (Diesel).
The only problem is, since I do not know much about this stuff, is if the alternator will be compatible with my car. In the Netherlands, where I live, there is not a high demand for these kind of modifications. And I really need an high output alternator since I will be using 3 Sundown Audio amplifiers. And I really think my current alternator will not be able to cope with the demand.
Anyways, I was wondering if there is a big difference in alternators between gasoline cars and diesel cars. I know America does not use Diesel cars (or anyways not a lot) compared to Europe. So I was wondering if somebody can post the specifications of the alternators, so I can see if there is a difference between them, other then output.
Currently, the only one who can supply me with an high output alternator is Iraggi (Dominick). It seems he really does know a lot about alternators, but is a bit slow in the answering-emails department. Also since these alternators cost a lot of money, I am just wanting to make sure it will fit without problems. Iraggi said it would fit without problems. The maximum alternator he has for my Lexus IS 220d is a 220A alternator. Which should be enough for me.
Please advice or share your opinions with me, before I make the purchase. I really hope someone can give some good advice.
By the way, just FYI, you can here see my car hifi setup (almost 100% complete, except for the subwoofers): http://www.mvdl.info/hh_lexus.jpg
Thanks in advance already for reading!!
I think you are better to post in the Aftermarket Audio section.
You can get a 2nd battery installed in the trunk as an option. You can also get a few CAPS in your trunk for heavy loads. I have used both in previous cars and the CAPS help a little but it depends on how crazy you are getting.
What about going to a custom Audio place locally to you and seeing what they suggest for some expert advice you what you are doing for your system. Then get online and do some research???
I just need some more information about the Lexus IS-series alternators if possible. Also custom audio places overhere in the Netherlands aren't very good concerning alternators & Lexus' cars.
again if you read my post you should have posted in another section??
here is the link to make it easier for you:https://www.clublexus.com/forums/lexus-audio-video-security-and-electronics-12/
from there I just added things I had done. Post in the right section and I am sure someone will be of better help! sorry I was only trying to help...
twizted
SC- 1st Gen (1992-2000)
08-06-10 05:50 PM
