hid kit install require drilling???!!
i just order a set of hid conversion kit..
and i was going thru some of the diy threads on install and the one that everyone seems to link to shows that you have to drill a 1 inch hole???
doesn't stock bulbs need wires to come out?? so shouldn't there be a hole already???
im kinda confused..
thanks for any tips
im kinda confused..
thanks for any tips
im kinda confused..
thanks for any tips![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
im kinda confused..
thanks for any tips
The stock bulbs have wires, but the HID needs the ignition/ballast box to power the HIDs. This is to first fire the 50,000V needed to start the HID and then the 35W to maintain the lighting.
The stock wiring goes straight to the bulb. Since the box won't fit in the light housing, the wires need to come back out, go to the ballast, and then back into the housing to your bulb. Since the stock wiring hole won't fit all that, you need to drill.
Drilling is okay. The kit should come with a grommet that should seal out any moisture from the light housing. If you don't feel good about it, buy some high heat caulking material to seal it off.
BTW, it's really, really easy to do. You can either fork out the $3 to buy the drill piece yourself from Home Depot or ACE or any hardware store; or find someone in your area who has it.
the problem is i dont know if the kit comes with grommets and on the list of items contained.. it doesn't say grommets
and i have no drill to put the drill bit on.. lol i can get my friend to help out tho..
but it seems like a lot of work.. my friend just did the same kit on 2 other cars.. a scion and a toyota.. and they both were simple plug and play..
is there no way around this drilling??? can i buy grommets seperate?? if so .. where??
thanks for the help btw
Drilling is required for most if not all projector/1-piece headlight housings, which usually have a seperate connection port for all the wirings. There is a cap in the back of the headlight housing for bulb access, and that's where you need to drill the hole at to run the wires in and out of the housing.
rs/ss
GX - 2nd Gen (2010-2023)
10-28-11 04:59 PM
HiPSI
SC- 1st Gen (1992-2000)
25
04-16-11 07:14 PM
