Why is the trans default 4th gear?
downshifting increases wear on your engine and drivetrain components because the RPM is suddenly changing. Buy new tires if you want to increase your braking power
It goes to 4th gear because if I want to pass someone and I change to manual mode, it would be stupid if it stayed in 6th and then I have to paddle down twice to be able to pass
id have to agree with the committee for engine braking, lol
considering there is such consideration for it in the automatic... this is why you cant even downshift to 1 when ur in second... until it deems it safe.
Tech Info Resource
In the view of physics, stopping/slowing down the car with engine braking means putting (car mass)x(deceleration) = (Stopping Force) onto your powertrain. I would use engine braking for an MT since it uses a clutch instead of a torque converter, and generally a clutch is able to handle more torque than a TC. If you ask your mechanic, I believe he'll tell you the same thing.
If you really think there is value in engine braking, why do they put one way clutches on race bikes? Wait - because it upsets the chassis! So WHY do you want to do this with your car?
really? I thought the cars were built to withstand that kinda abuse.
I ALWAYS drive with my hand on the gear, downshifting excessively. Im renting a toyota corrola right now, and it has D, D with overdrive, 2 and L . Im always droppin it to overdrive and sometimes even straight from D to 2. Its become second nature to downshift.Sides it makes driving more enjoyable. Thank god for warranty.
Amen to that brother.
But in any case, I too am I user of engine breaking for slowing down on steep grades (when there's sloooooooooooow traffic in front of me) and when making fast turns when i'm driving spiritedly (if that's even a word). I try to take it easy on my tranny during stop n go traffic tho as not to overheat it unnecessarily and after a "Fun" drive, I drive at 45-55 mph for a few to "cool off" the car.
I don't feel that it upsets the balance on my car tho . . . It actually helps me power out of those oh so fun sharp turns
I would never ever buy someones car if I knew they used engine braking to brake because the engine and drivetrain will have considerably more wear than someone who didnt.
2IS OG
He'll tell you using the engine to slow the car is dumb and poor technique regardless of the transmission type. If you need to brake, use the brakes. If you need to downshift, it's because you need a lower gear to accelerate out of a turn, not slow the car going into a turn.
Also, the reason the transmission defaults to 4th gear is because that is the 1:1 gear in the 2IS. It's explained in the New Car Features section of the FSM. Here are the rules by which the different 2IS transmissions allow downshifting:
As you can see, 4th gear allows a top speed of 109, 113, and 109 mph, respectively. You have to be going insanely fast for 4th gear not to be appropriate for the speed at which you're driving.
Javier
you cannot downshift from secondgear to first untill you reached 30mph or below.. and i forget the rest of the gears but i do it all the time but i cant think of it right now for the life of me lol.. 1st gear ends at 40mp before it overrevs
i actually did the6th to 5th too.. (i drive home late alot on turnpike no po pos or traffic most of the time) but i dont remember that either..
i'll do it again next time :X
Tech Info Resource
I don't understand why a lot of you drive your car like it's going to break in the very near future. I downshift w/ mine all the time and sometimes even leave it in second driving around town so I can be ready to accelerate to dodge something or make an evasive maneuver. It makes driving just that much more fun. If you wanted to drive your car lika pansy..should've bought a benz or something.
Tech Info Resource
Not me either, sometimes I ask myself if my driving offends other people on the road... especially in my S4. We're just trying to take care of our cars whenever we can to balance out the time when we beat the hell out of them.
