Why is the trans default 4th gear?
I have yet to see an advantage to this. When I am cruising at 70 mph in auto mode and want to downshift for braking, I don't want my car going from 6th to 4th. Any idea on why Lexus programmed it this way? TIA
Its just a design characteristic. If you were going a lot higher rate of speed where 4th would be out of range, the sport mode switch over would drop you into 5th. Needless to say, if you were running a cannonball and topping the car out, going to sport mode will leave you in 6th. I have yet to try out the last one and ,quite frankly ,don't think I have the need to do so.
Lexus more than likely set it up this way to make the operator of the vehicle realize that sport mode is designed for performance. Its a Dr.Jkyll & Mr. Hyde thing, ya know.
-Joe
-Joe
-Joe
-Joe
I'd rather wear down my brake than my gears since brakes are so much cheaper to replace. Our IS's automatically downshift to 4th gear for you whenever you apply brakes while going downhill, but I always shift into 5th to avoid too much engine wear... I live on a hill and I need to drive 4 miles downhill everyday.
I can vouch for that, i do alot of highway driving at highspeeds, ive dropped it a couple of times and it drops to 5. Having seen it drop in at 6 (maybe once but cant confirm) Its a smart tranny and i use it all the time for engine breaking. While i doubt this will cause me any problems cant say the same bout the cars future owner though lol.
What sparked my question relates to smooth driving. If driving in manual mode, it's impossible to downshift on the freeway w/o making it known to your passengers you have to alter your speed.
LOL!! Some passengers get special treatment, ya know? ; )
downshifting increases wear on your engine and drivetrain components because the RPM is suddenly changing. Buy new tires if you want to increase your braking power
It goes to 4th gear because if I want to pass someone and I change to manual mode, it would be stupid if it stayed in 6th and then I have to paddle down twice to be able to pass
In the view of physics, stopping/slowing down the car with engine braking means putting (car mass)x(deceleration) = (Stopping Force) onto your powertrain. I would use engine braking for an MT since it uses a clutch instead of a torque converter, and generally a clutch is able to handle more torque than a TC. If you ask your mechanic, I believe he'll tell you the same thing.
