About to install HID Fog and paint calipers
I have a couple questions. I am about to install my HID fog 3000k fog lights tomorrow that I bought. It is brand: xentec. It comes with ballast, bulb, connector but it doesn't include the connector to the battery. I will be following the installation on passnu DIY.
1. Just wondering, where do I mount the ballast to? How do I zip tie the ballast inside the fender liner? How do I connect the connector from the fog light ballast to the car?
2. Also, I will be painting my calipers black with white stickers already purchased but wondering is it OK to paint the circle thing as you see in the picture below:
![](https://i72.photobucket.com/albums/i180/cdeslandes/PICT0088.jpg)
3. Since my car is only 1 month old. Do i really need a wire brush to clean my brakes? I have brake cleaner that came with my kit though.
4. How do I install the rear caliper sticker? The rear brake caliper look so small..
where do I place it at?
5. Will I need to leave my car on jack stands over night for the paint to fully dry (which some people say it needs) or can I just wait couple hours?
Thanks
Thanks
ok since i recently did my brake calipers and its fresh in my mind let me give you some tips:
MOST IMPORTANT: its all in the preparation. you need 2 cans of brake cleaner, one bought/one from the kit, save the kit one for the rear brakes since the one you bought is most likely in a bigger can, spray the cleaner and brush with a wire brush (i used a brass type) and clean it good, spray again to rinse off the excess and let it dry, then use a damp towel to wipe the brakes AGAIN, you'll see how dirty it is even after using brake cleaner/brush. let it dry.
Masking, do a good job here (is all i can say)
Painting: DO NOT use the brush with the kit, go to a hobby store and buy a REAL camel hair brush with a flat bottom, shake the can well before you open it, for your first coat go lightly DO NOT layer it on, even thou it not 'covered' its just the first coat, let it dry for a hr or 2, then go with the 2nd coat and do a good job, let it dry 2-3hrs, put the rims back on carefully and let the car sit for a full 24hr day before you go driving around.
you can apply the sticker before you put the rims back on, the paint should be dry. as for rear brakes sticker... hahah forget it, theres no place to put it![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
OH YEA, you CAN paint your hub if you want, i didnt... but i might for the NEXT show so at least something will be different
Just zip tie it around the white case for the Fog Light. Look at the DIY install I posted that you are following. They stay just fine and its got a flat surface on one side. I used a few zip ties together as they are not long enough to wrap around. You can purchase longer ones if you want. PM me if you want more help![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I did not paint this on my car but I do not see why you cant so long you dont get it on the rotors. Many aftermarket rotors come this way! I think it will look much better...
Mine is close to 2 years old and I did not. The can of brake cleaner that was in my kit was enough for both my cars and I still have 1/2 can of paint left if not more. I found getting a 1" brush from the hardware store was easier to apply the paint then the lousy brush they gave!
when you have the rim off and you are applying it you will see! easier to tell when you have it all in front of you. You don't have to use the rear if you don't like them. just place it before you remove to stick it on to eye where it needs to go!
I put my rims back on the car about an hour after. The rims will clear your BBK so just take your time putting them back on so you dont bump them. It dries pretty quick IMO.
Thanks
Thanks
here are my pics if it helps...
![](http://i37.photobucket.com/albums/e65/mjpace74/IMG_0033.jpg)
![](http://i37.photobucket.com/albums/e65/mjpace74/IMG_0034.jpg)
As Mike posted above, the 350 has larger nicer calipers that are non porous on the outside that aid in the sticker application. It is amazing how a simple mod makes the car look so much better IMO. The sticker set really makes the calipers stand out as well.
The kit you can get online or at your local auto store. Its called Duplicolor.
read this thread and you will see the ones I have and also another style from another member. You have choices. Just read threw the 4 or 5 pages and the info is in the thread
https://www.clublexus.com/forums/sho...liper+stickers
Ok got a few question. I painted my caliper last night. It seem like the 08 is350 is dark grey so i painted it black it didnt seem to be a dramatic difference. I only painted it 1 layer for now and i pop on my wheels because i have no time. But the first layer seems pretty nice. Looks good. Not sure if i need second coat.
Also, i tried taking out the fender liner. It seems like it has 2 flat head clip. I cant get it out because i dont want to break it. My last car stupid clips cost 10 each. But anyone know how to take it out? Thanks
