Another quick tire question.
dont go with 275/35, it should be fine with 265/30 . and as for the front use 225/35. Trust me i had those tires size on mine's , it put me in the rubs cityz, with the drops of tanabe. Bad idea
are you doing or have you done any fender mods??
rear will work if you roll the fenders....265/35 will give you more play. I run the same tires front to rear with no troubles with 1.6 drop front and 1.2 drop in rear. I can go lower in the front but I would bottom out where I live all over the place. I do not see any problems with your tire sizes....
225/35/19 (f)
265/35/19 (r)
this is what I would do since you do not want to mod the fenders.
I have 235/35-19 front with no mods and I do not rub but I am only lowered 1.6" not sure how low you will go. I will find a pic for you. the rear I did roll the fender but 265/35 I would not have needed to roll. I only rubbed on big dips and bumps before I rolled the fenders on the 275/35 in the rear.
front:
rear:
265/35/19 (r)
front:
rear:
Ummmm I just wanted to add this here because I was doing some tire research myself and some other forum posted this link:
http://www.1010tires.com/TireSizeCal...?action=submit
I thought this would be the appropriate thread to put this in. Hope this helps someone.
thing is thou, if you firm up your coils you wont rub on big dips BUT~ you'll loose the lux ride, its a balance between looks n comfort... i prefer looks OF COURSE if you get Airrunner... then you'll have NO PROBLEMS what so ever
Big thanks to Passnu and llama. Seems like I'll be safe with getting 235/35/19 front and 265/35/19 rear. If Passnu was fine with 235/35/19 with +33 offset, I should be fine with the same width with +35 offset, but a bit lower. I'll just stiffen up the coils a bit more like llama said. Or should I just stretch a bit just to be on the safe side... decisions decisions
ok one thing about the 'big tire' vs 'vip stretch'... the vip stretch is just plain sexy BUT~ potholes/taking a curb at a wrong angle/parallel parking and scraping the curb WILL damage your rims... the big tires wont have that problem of rim damage BUT you can mess up your fenders/rub n blow a tire/everything with big tire depends on drop/offset/mod the fender or not...
its the balance for any type of 'look' other than stock that you need to be aware of and plan for it in advance. 'drop/offset/rim size/look you want' BEFORE you buy the tires/fender modding... its usually the smart way, but hey who wants to do things the 'smart' way anyway right? POUND UM, BROKE UM, FIX UM and POUND UM AGAIN
