Check VSC with less then 200miles! (resolved - gas cap not tight)
Hello all.
I got a check VSC message on the dash this morning when i started up. The car seems to be running fine, i tried restarting but same thing pops up. It has less then 200 miles on it. I am going to see if it comes up when i go to lunch today if it does looks like ill be calling the dealer. Anyone know exactly what the error means?
I've seen threads about people getting it after filling up and not tighting the gas cap, but i havent filled the thing up yet its still on the dealer fill up. Thanks
I will give that a shot and see if it fixes the message thanks.
Keep in mind that the "Check VSC" check doesn't happen at every startup. There's a timer or some sort of mileage counter instead, so even if you fix the issue, you'll have to drive around a while before the light will turn off.
Anyways i tightened it to the one "click" and drove around to pick up lunch. Check VSC stayed on, and when we were leaving the restaurant it was on again.
Sorry Joe what is PDI? Please dont tell me there is something wrong with the car...this already is the 2nd car as the first one that we picked had an ignition problem and they had to do a dealer swap to get this one.
Super Moderator
Unless you live very far from the dealer, I'd bring it back and have them look at it. They'll plug in their scan tool, read the trouble code (or codes), and determine why the light came on.
PDI is pre-delivery inspection. It's a thorough check of the vehicle that the service department is supposed to do before it is delivered to you.
hope all goes well!
I'm guessing nothing more than... drumroll please... tire pressure sensor. Make sure your monitoring set 1, and not set 2!!!!!
You can check by using the setting and arrows to the left of your steering console.
IMO I think you are fine and I would do the same. Just call them and tell them you will be there on Tuesday and can the do both at the same time. If they feel its important for you to be there sooner they will tell you. You have road side if something where to happen. Yes not fun but at least you have piece of mind just in case. I have to take my wifes Acura in for a similar reason but her car is about a year old. They said to wait till tomorrow and they would have a loaner. except on her car its the check emissions?? never had that one before so since she drives it and its under warranty I want them to check it over.
hope all goes well!
hope all goes well!
Could that setting change on its own? Cause i havent changed anything since i took delivery on weds.
11 Second Club
Ya i just got off the phone with the service dept and he said they might need to replace the gascap if it truely is not holding the seal. But he said they would need to clear the error anyways. He said it wasnt a big deal unless that error starts flashing or the car starts driving differently. They will take a look when i go in for the radio install.
I took it all the way off. Then put it back on but like i said it didnt feel like it was really locking in place. Ya i have Check VSC, traction control light is on (which means its off ) and check engine was on as well.
