Yes, it's the lower grill. can it be taken off and put back on? some small objects (looks like white pebbles) got through the openings of the grill now sitting inside of the bumper. I could see them but can't get them out unless I remove the lower grill...
there is enough opening in the front engine compartment if you take the cover off to stick in a vaccum hose to suck the pebbles out save you the 2hr + to take off the front bumper. If you look in the sticky thread of HID install there is steps on how to take off the front bumper
I got it off without removing the bumper since I'm installing some hidden laser jammers to peek out of that grill. If anyone is still wanting to know how to remove that I can take some pics.
I want laser jammer too. Which one did you go with? Did you install it yourself?
You will need to remove the front bumper to remove the lower grille. If I recalled directly there are approximately 8-10 plastic clips (4 on top and 4 on the bottom)<- they are part of the lower grille. After you remove the front bumper, for the top portion of the grille- just push down and outward. For the bottom, push it up and outward. The grille will pop out when you are done with all 8-10.
