Steps to UNLOCK all doors after pressing driver handle button
hi
does anyone know how to change the setting of unlock all doors after pressing the button on drivers side door
Thanks for answer
Thanks for answer
Lock your car. Press and hold the lock and unlock button on your key fob till you hear the car beep, it should unlock all your doors. Do the same thing if you wanna go back to original setting
The two front door handles have a sensor on the inside part that unlocks just the door that you are standing next to (edit) when you grab that door handle. You can configure the car to unlock all of the doors whenever you grab the door handle, the owner's manual tells you how to do this. Look it up in your manual.
After a recent move, I'm still searching for my Owner's Manual!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Doesn't appear to work here. I've got the unlock all thing set up if I hit unlock on the key fob. But using the door handle sensor to open the driver's side, it only does the driver's door...?
Do you touch the lock button on the door handle or put your hand inside the handle to unlock as the final step? Also, are you holding the lock/unlock button while reaching for the handle?
I just luv CL members. LOL
I always wanted this done, and i took it to Newport Lexus one time and told them i wanted this done, but they informed me that they it was not an option for security reason. psssssh, I'm guessing they were too lazy to press the unlock & lock button at the same time.
Thanks for your help!
You have me second guessing, but I unlock all 4 doors by grabbing my handle (triggers unlock sensor), moving my hand and doing it a second time. First time unlocks Drivers Door and Second all the others.....
