License plate light?
Just wondering what bulb size do you use on you IS models for the License plate because every time i see an IS the license plate light it looks so clean. I have switched my bulbs twice with the led lights and cant seem to match the ones off your cars its just not as bright for some reason thanks
thats what i heard too that the license plate bulbs were soldered in that why i just wanted to make sure. I bought led bulbs and compared them to the IS lights and they are way off no comparison. I thought it was the bulbs that i bought so i bought a diff. set and still the same results. i think the Sylvania site is wrong sometimes
Correct. You can't get the bulbs separately, you must buy the lamp housing/assembly. They are about 80 bucks each from Lexus.
did you try the new" 2w " high power bulbs yet???
![](http://a763.g.akamai.net/7/763/1644/2/app.infopia.com/img/image/fp/VPID/5768086/extra/2)
M-SMT High Power Flank
2 Watts of pure LED power. Designed for right angle applications, if your bulb sits in sideways, or 90 degrees then this is the bulb you need. Our M-SMT bulbs use the latest in High Power LED technology. This bulb has a full 180 degrees of light side to side. Color is consistent through the M-SMT line, similar to white/blue 6k HID lighting found on many high-end cars or aftermarket HID headlight kits. These are bright, nearly 10 times brighter than a standard LED for this application, so that's like having 40 LEDs on this little bulb!.
