Please sunroof bracket makes noise on IS350
please help, does any of you have the same problem? my sunroof makes click noise when go on uneven pravement. is a bracket that hitting each other, please check picture, please help, it's annoying. Thanks
I had the same problem with mine. I brought it to the dealer and they covered it under the warranty. They wound up wrapping some felt tape around the contact points.
Mine does not do it when tilted, but makes a rattle noise when retracted...drives me crazy. I recently had the moon roof weather strip replaced and moon roof re-aligned, since the fix I have noticed th noise. I guess another trip to the dealer
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Tech Info Resource
If the car is new, it is definitely covered under warranty. If you bought it used, you may be on your own.
tejanp
01-11-24 07:30 AM
