View Poll Results: How many miles did you get on your original tires?
Have not had to replace them yet
177
68.34%
Replaced at 15 k miles
14
5.41%
Replaced at 20 k miles
28
10.81%
Replaced at 25 k miles
15
5.79%
Replaced at 30 k miles
18
6.95%
Replaced at 35 k miles or more
2.70%
Voters: 259. You may not vote on this poll
Mileage Check - Anyone replace their tires?
#91
invest in aftermarket wheels. i only have 13k on my car and inner wear is bad. i had them swapped and remounted. hopefully i get another 10k. but i decided to get some new shoez
#92
Very impressive to get the mileage you did out of those OEM tires. I have 15k or so on mine and I will probably get about another 5k out of mine if I am lucky. Having put the OEM rims and tires back on last weekend I must say the RE050a tires are very noisy and do not offer what I had. But you get what you pay for and these are a fraction of the PS2's I had on the car.
If you have Discount Tire in your area they have been great to me for many years See what they can offer you!
#93
Wow.... 32k on those tires? My tires were down to 30% when I had only 12k then I switched to aftermarket wheels and tires. As long as you don't mix the tread pattern within an axle, you should be fine, but I would get all 4 tires at the same time with an alignment like others suggested, I don't think the rears will last too much longer.
#96
So i'm replacing the stock tires in the front (Bridgestone Turenza ER33) due to inner tire wear, which means i'm keeping the back tires right now. I'm debating whether I should keep the same tread on the front, or should i find another set of tires for the front and switch out the rears later on. The reason I ask is because I can't find the turanzas anywhere near my place and the cheapest i found it for was $242/tire.
I remember I used to switch the treads ...... only on the rear/front respectively, not driver/passenger. It's just that, if I get into an accident, will the insurance company penalize me for not having same set of tires on all fours?
Any Advice???
btw: i have 32k miles. Are these tires supposed to wear out by now?
Any Advice???
#98
Tech Info Resource
Threads merged. New tire threads about mileage will be merged into this thread.
#100
Now I get to answer my own poll. I finally replaced my tires at 35k miles. Probably could have gotten another 3-5k more miles, but one tire had a slow leak and the tire shop said it really wasn't worth fixing.
Since I live in the Northeast and drive an IS250 AWD, I wanted good all-season tires. Based on Consumer Reports and Tire Rack, and price, the Conti Extreme Contact seemed like a good choice.
I don't know that I would recommend these tires, though, because they are much noisier than the stock Dunlop tires, especially on newly paved interstate highways at speeds over 70 mph. This was a bit of a disappointment, since the noise ratings were not flagged as a problem in the CR review.
Anyone else have a similar experience with the Conti's? I'm thinking about having some extra soundproofing installed.
#103
About to replace my front stock Bridgestones at 17k. The outer edges are worn, especially on the passenger side. I've noticed some people experience the same type of wear. Think I'm going with Nitto Invo's since they have good reviews and aren't directional so I can rotate them.
saifm73
06-28-20 09:12 AM
Technique
07-24-08 10:09 AM
