Yellow Fogs.
Im looking to see if i can change the actual fog light. To yellow i have seen other cars that have it but im not sure if its the housing or fog overlay.
If you are looking for the actual light to iluminate yellow then you will like the look of 3000k hid conversion. See our forum sponser mobilehid or xenondepot for more info. "FYI if you contact cliff at mobilehid he is very helpful and fast to respond". Or if you want the actual glass to look yellow then you will want the yellow overlay. The Hid 3000k yellow will look fantastic at night and give it more a JDM look at night. IMO![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I personally just installed this kit! I went with 5k as I wanted a different look then you but all around its been great!
Mike
Former Sponsor
Hi,
Your vehicle uses a 9006 bulb for the fogs. If you wanted to go with an HID set up I would suggest going with a 9006 3000k HID conversion kit.
Here are some pics of our 3000k kit installed on an IS along with our 6500k kit installed in the low beams:
http://www.kbcarstuff.com/Lexus_IS25...reme_s/188.htm
Steve
Steve
Hi,
Steve
Steve
The overlays will not melt if you're going with the high temp ones. Most of the reputable companies that makes overlays specifically for the ISx50 will not make one that can't withstand high temperatures.
