Road and Track 0-60 time of 4.9 seconds.
Old 07-01-08, 08:48 AM
IS350jet
IS350jet's Avatar
^^ Still seems impossible to be that accurate. Police radar is constantly coming under fire for being inaccurate. Imagine trying to get radar precisely accurate, down to 1/10 of a second while rapidly accelerating. Anyway, I was curious to know how magazines get their 0-60 times so I fired off a letter to the editors at C/D. I'll post their response when it arrives. I'm curious too.
Old 07-01-08, 10:59 AM
maxnix
maxnix's Avatar
Transmission braking at 4K rpm constitutes abuse and would cancel your warranty if Lexus knew.
0 -60 mph time is so irrelevant anyway. Passing time 50 mph - 90 mph counts so much more in the real world.
Old 07-01-08, 01:13 PM
IS350jet
IS350jet's Avatar
Car & Driver got back to me pretty quickly.
Originally Posted by Car & Driver
The backbone of our testing program, and also our newest piece of equipment, is the Racelogic VBOX data logger, measuring equipment that can fit in a briefcase. After a lengthy trial period, the head office ponied up for two of the $10,000 systems.
The VBOX can record speed, distance, lateral and longitudinal acceleration, and position. We use it to record acceleration, braking, and top speed.
The VBOX communicates with the U.S. government's global positioning system, a constellation of 24 satellites that orbit the earth 10,600 miles overhead. At least four of the satellites are above the horizon at all times, and each sends a carrier signal that is picked up by the VBOX's antenna (a small magnetic unit that you affix to a test vehicle's roof). As a vehicle travels, it draws nearer to some satellites and farther from others. As this happens, the frequency of the carrier signal shifts minutely. The VBOX senses this frequency shift, which is also known as the Doppler effect, and calculates the velocity, acceleration, and distance traveled.
Here's the entire article.
http://www.caranddriver.com/reviews/...t_cars_feature
Old 07-01-08, 01:19 PM
Gernby
Gernby's Avatar
If they are using GPS to measure 0-60, then radar would be a total cake walk!
Old 07-01-08, 01:45 PM
RocketGuy3
RocketGuy3's Avatar
0-60 time gives you a good idea of how you'll do in street light races where you don't want to exceed the speed limit very much.
Old 07-01-08, 04:28 PM
Lextasy89
Lextasy89's Avatar
yea that was a "mis-post" .. if i brake-torqued to 4k id be sitting still in a cloud of smoke.. i usually dont even get to 1500 rpms..
all you gotta do is hold it for a sec, let off.. and take off!!
Old 07-01-08, 04:31 PM
Lextasy89
Lextasy89's Avatar
Originally Posted by meowCat
^ You don't need to put 4000 rpm to brake-torque launch. Whoever did that wasn't very smart anyway. All you need is 1k~ 1.5k rpm to launch. 4k is your imagination.....
I'm not crazy about 0-60 either, but it is nice to know what your numbers are. There is nothing wrong with that. What I am interested is 0 to quarter mile and upto 125 mph where the IS350 shines. Remember, the 4th gear tops out at 125 mph at 6400 rpm. The 4th gear isn't weak at all for this 6 speed AUTO. ho..ho
yea.. i really like the power through 3rd gear.. but once im close to 100.. thats when the faster cars start to shine and whoop up on me..
Old 07-01-08, 06:54 PM
caymandive
11 Second Club
caymandive's Avatar
Originally Posted by dominant1
its bs lexus paid them to say that.. if it were true then the isf goes 0-60 in 4.2 seconds...
Actually the IS-F was reported in this months Road and Track to do it in 4.2 seconds.
Old 07-01-08, 07:56 PM
Lextasy89
Lextasy89's Avatar
ehh well hp isnt the only thing that comes into play.. the is350 is geared much lower then the isf.. and weighs less!
but obviously if you put some 4.08's on the isf it would be insane in the 0-60.. could break into the high 3's pending traction (drag radials needed)
Old 07-01-08, 08:05 PM
Ramon
Ramon's Avatar
What I am saying is, the 4.9 sec is STILL CONSERVATIVE number.
No, it's not conservative at all, when much of the rest of the world is in the low 5's in this car. Just beucase a select few have reached 4.9 and even fewer less than that, doesn't make it conservative. Likewise, just beucase a select few (very few) have hit times like 13.1 on a stock setup, doesn't make the IS350 a low 13 second car.
Old 07-01-08, 10:17 PM
Lextasy89
Lextasy89's Avatar
maybe not everyone can get a 13.1 stock.. but its def a low 13 sec car
Old 07-02-08, 12:09 AM
Ramon
Ramon's Avatar
In the biased eyes of Lexus fans it may be. In the eyes of an objective individual (everyone else) it's a mid 13 second car.
Old 07-02-08, 04:13 AM
caymandive
11 Second Club
caymandive's Avatar
Let me clear all this up. At close to sea level and temps of 70F and higher this car is a mid to upper 13 second car. Temps below 70 will be Mid to low 13's. It's that simple.
Old 07-02-08, 05:02 AM
caymandive
11 Second Club
caymandive's Avatar
so how would a a cold air system and exhaust impact those times?
The stock intake system is already cold air.
Few things I have noticed about the IS350.
1. Full exhaust with gains of around 10whp knock off about a 1/10th
2. Every 30lbs lost knocks a 1/10th off
3. For every 10 degree drop in temperature is worth almost 10whp on the IS350 so you can presume another 1/10th for every 10 degrees.
Old 07-02-08, 06:07 AM
SikTT
SikTT's Avatar
3. For every 10 degree drop in temperature is worth about 10whp on the IS350 so you can presume another 1/10th for every 10 degrees.
WHAT?!?!?!
For every 100lbs lost knocks off .1
How is it different for a IS350 than any other car?????????
And 10rwhp for every 10 degree drop? Where did you get this from? I am very curious now. It's like a 1% change in power.
Quick Reply: Road and Track 0-60 time of 4.9 seconds.
