Vsc
check VSC and check engine warning lights stay on and the Traction control switch doesn't work...does anyone knows how to correct this?, it when off after I reseted the electronics by disconnecting the negative battery connector for 10 minutes but after driving it for awhile for 10 miles it came back on
check VSC and check engine warning lights stay on and the Traction control switch doesn't work...does anyone knows how to correct this?, it when off after I reseted the electronics by disconnecting the negative battery connector for 10 minutes but after driving it for awhile for 10 miles it came back on![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Make sure you have all the hoses tightened. I was messing with my F-Sport intake and forgot to tighted one of the hoses and got the same lights on. Too much air was coming in. Tightened and no more lights
