IS350 pulls to the right...
#31
Shahryar,
Being in range does not imply it is dialed in correctly or perfect for the car, therefore your alignment could still be out for it. For instance, it could be on the extreme edge of being close to out out but still within green. It's more of fine tuning it to be correct for your car.
I'm mainly assuming alignment mainly. If it is your tires, that can affect it too which I treat this as a seperate issue; you will need somoene who his experienced in tires to look and feel the tread as well to verify.
The alignment shop I go do, does all this do I do not have to worry about issues about how my car performs.
#32
^I hear you on the alignment being a factor. Just someone else mentioned it was w/in range so I thought that wouldn't be it. I just finished reading through the excessive pull to the right, anyone else have this problem in their F? thread and in all the cases there, it was an alignment issue.
but for me and Mong, the OP of the steering wheel doesn't return to center position? thread, the issue seems to have started w/ the new Hankook Tires. But yeah, if the Tire replacements/swaps don't do anything, Alignment is what I'll be eying. Also when I put my winter tires on in about 4 months I'll follow shortly with an alignment. I'll keep your alignment sheet as a model to give to the tech.
How is your alignment for performance vs maximizing tire life? I don't want to give up too much of my fun factor. That's what I signed up for when I went w/ the IS 350 versus another car.
#33
^ You mean mine assume.
For me, when I had my alignment done, the alignment person (Byron), aligned and tuned the car according to my driving style (from the questions he asked like, use for street, racing etc...). Since I said general street use, it was set this way. From my guess it is probably mostly maximizing tire life and having some performance from my guess as I did not go in detail and asked him specifically this question.
Currently I have about over 17K on the tires and had them rotated at 12K and the tire wear is great so far. I get my tires checked about every 5-7K by Byron (his recommendation) so he can check the tires/pressure to see how they are doing to see advise if any adjustments is needed if an issue arises.
#34
2011 IS250C Death Trap
I set my steering wheel straight and my car goes straight--so far so good. But as soon as I let go of the steering wheel, my car slowly pulls to the right. So I took my car in to a dealer for an alignment. After the alignment, I tested my car over a week and it still has this same problem.
Anyone else having this problem too?
#35
same boat my is250 awd pulls to the right when I let go of the wheel not just a little bit by a lot. Went to lexus and they said it was "normal" there is some sort of chip in the car that makes it pull according to the way the road goes... lol sounds pretty far fetched to me. :S thinking about rotating my wheels and seeing what happens
#38
How fast are you guys going to feel the pull on your cars? I usually go about 40mph on a smooth, flat road or parking lot to check for pulling when buying a used car. If you are going on the freeway and going 60 to 70mph, then you probably feel some pulls because of the road or tires. I don't think you should be taking your hands off the steering wheel while driving on freeway speed.
#39
Morrissey
08-03-06 12:12 AM
