Noise from the Rear when going over BUMPS !!! HELPPP
Old 07-02-08, 08:25 PM
DaveyIS
DaveyIS's Avatar
Default Noise from the Rear when going over BUMPS !!! HELPPP
So my car has like 5000kms on it at the moment but this is a problem i have had since 2000kms. When i hit a bump i hear a squeek in the back, i took it to the dealer they said something like my foot brake was loose or some crap like that. They took apart the caliper and greased up the brake pad. That seemed to solve the problem on the passenger side, but now the drive side is doing it and its coming back on the passenger side i dunno what it is... Any one else have this problem?
HELPPPP its a 2008 IS250
Old 07-02-08, 08:26 PM
FiveOhNine
FiveOhNine's Avatar
Use your e-brake every day/night. When you park your car, but the e-brake on (hard). See if it goes away.
Old 07-02-08, 08:30 PM
DaveyIS
DaveyIS's Avatar
i use it all the time, its so annoying this noise every little bump sounds like metal scratching metal for a sec weird
Old 07-02-08, 08:37 PM
FiveOhNine
FiveOhNine's Avatar
interesting.....might want to check the dust shields.
Old 07-02-08, 08:40 PM
DaveyIS
DaveyIS's Avatar
they checked that no rubbing or anything. do u think they will warranty it if i have changed my suspension or it doesnt matter? it was happening with my stock suspension and its the same with the coilovers...
Old 07-02-08, 09:06 PM
triple_c
triple_c's Avatar
try pushing down on the spare tire compartment in your trunk. i'm not sure if this happens to anyone else, but something in my spare tire compartment squeaks. when i'm driving slowly over slightly uneven roads, i can hear it squeaking in the back.
Old 07-02-08, 09:51 PM
fishnfool
fishnfool's Avatar
Try pushing in and holding your e-brake over a bump that you know will cause the sound. If the sound disappears, your e-brake may need adjustment. Good luck.
fishnfool
Old 07-02-08, 10:11 PM
Stealth.GS
Stealth.GS's Avatar
Mine does the same thing 2008 and it happened from day one wasn't sure if everyones did this. Mine comes from the back passenger side.
Old 07-03-08, 08:04 AM
AKIS350
AKIS350's Avatar
I think i have the same problem..
It squeeks everything i hit a hole and its only in the back..
I took it to the dealer but they didnt do nething bout it..
Old 07-04-08, 06:38 AM
dw8787
dw8787's Avatar
I would say it almost sounds like rear spring slap but if you have a stock suspension or coilovers it kind of rules that out.
Old 07-04-08, 04:29 PM
ISWillie
ISWillie's Avatar
When i hit a bump i hear a squeak in the back
Did you have the dealer check to see if they accidentally installed the 'mother-in-law' option in the rear seat?
Old 07-04-08, 04:51 PM
i3urton
i3urton's Avatar
yes joez has told me about this problem and now ihave no sounds...
Old 07-10-08, 09:13 PM
DaveyIS
DaveyIS's Avatar
ANYONE!!!!!!!!! its so annoying dealer couldnt fix it im going to try another dealer but any answers?
Old 07-11-08, 06:26 AM
dw8787
dw8787's Avatar
Is your suspension stock, or are you running new springs or coilovers?
Old 07-11-08, 06:31 AM
passnu2
passnu2's Avatar
can you have someone sit in the backseat while you are driving to pinpoint the area the sound is coming from??
D&G
01-28-14 10:31 PM
Daniely30
01-12-13 01:20 PM
DREGS3
Suspension and Brakes
03-04-11 08:23 PM
shelly79
11-30-09 02:03 PM
Valet Park
Suspension
08-20-06 10:05 PM
Quick Reply: Noise from the Rear when going over BUMPS !!! HELPPP
