body tolerance
Old 07-04-08, 05:39 PM
retaj
retaj's Avatar
Default body tolerance
My search has begun for an IS 250 Manual. Today, I took a close look at one. I noticed that the bumper cover and fender intersection on the driver's side was off by half a 2-4 mm. I found a 350 today too, and it seems it's intersection was also off by the same amount. No other body panels were off.
How's the tolerance on your body panels?
I am also a little suspicious that the white paint is a little off on the bumper cover as well.
Old 07-04-08, 06:08 PM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
Maybe It was replaced, was it used?
Old 07-04-08, 06:13 PM
Scottina08
Scottina08's Avatar
your joking right?
Old 07-04-08, 06:16 PM
retaj
retaj's Avatar
Yes, to clarify, they were both used. I am just doing a sanity check because the two used IS's I was able to look at today had the same issue.
Old 07-04-08, 06:57 PM
iKenn
iKenn's Avatar
Maybe both had the front bumper replaced or repainted. i dont have a gap.
Old 07-04-08, 08:09 PM
slee18
slee18's Avatar
mine was replaced due to the dealership screwing it up. It has not gaps like that either.
Old 07-04-08, 09:31 PM
Burrcold
Burrcold's Avatar
That's the nice (or bad) thing about white paint...it's really hard to match. Especially when it has pearl.
If you are buying used, you will almost always be able to tell if there is any paint work. On that same note, it sucks when you want to paint a non-factory lip, spoiler, etc.
Old 07-05-08, 06:38 AM
SebsIS350
SebsIS350's Avatar
one person posted a vid of the IS being assembled and they stated that all body panels are measured to be within 2mm tolerance
newyerker
ES - 6th Gen (2013-2018)
09-04-17 09:23 PM
alishab786
Maintenance
10-29-13 04:58 PM
ming15237
IS F (2008-2014)
10-14-09 06:35 AM
zzang
01-29-09 07:34 AM
z16
08-29-06 12:08 PM
Quick Reply: body tolerance
