Oil Help
Old 07-08-08, 01:59 AM
chickenass
chickenass's Avatar
Default Oil Help
I am about to do my first oil change for IS250 MT and I would like to know what oil would you guys reccomend me using. I live in NYC so weather changes often. thanks
Old 07-08-08, 03:20 AM
nabbun
nabbun's Avatar
5w-20. if you do a lot of "high speed" driving, then get 5w-30. if ur upstate, and it gets frigid in the winters, u could possibly use 0w20 for better start ups in those -20 mornings with 50 foots snow falls lol
Old 07-08-08, 09:24 AM
XhyDra
XhyDra's Avatar
I just did an oil change yesterday,
I used Royal Purple 5W-20 6.6qt.
I can notice a performance difference,
it feels smoother & gas seems better.
Old 07-08-08, 11:43 AM
wolverine
wolverine's Avatar
Originally Posted by XhyDra
gas seems better.
you noticed that in a day? i should try this stuff
Old 07-08-08, 12:02 PM
nabbun
nabbun's Avatar
hehe i'm about to switch up to RP 5w-20 also when I go for my 15k service.
Also to keep this relative to the OP's question, it's about which grade of oil to use for his application. He lives in NY and faces all different temperatures around the year. Cold snowy winters to Hot and sweltering summers.
I suggested 5w-20 for regular driving like if u lived in the city. perhaps 0w-20 if you live upstate like buffalo. you could use 5w30 or 0w-30 if you experience lots of load/high speed ie Racing or towing/trunk and car full of stuff
Old 07-08-08, 12:58 PM
chickenass
chickenass's Avatar
hmm ok so im guessing 5w-20 wont be great for all year round is it.. and i should change to 5w-30 for winter time.
Old 07-08-08, 01:14 PM
HKS350
HKS350's Avatar
http://www.mobiloil.com/USA-English/...l_1_0W-30.aspx
Old 07-08-08, 02:47 PM
nabbun
nabbun's Avatar
5w-20 is fine. the numbers on the oil ratings tells you how heavy the oil is going to be at startup/warmed up.
so 5w-20 is the weight of 5w when u start up so it's light enough to get moving around and lubricate well in cool/cold weather and 20w when the engine is all warmed up.
you don't have to change out the oil in your call for summer and winter unless you are driving that much and would like to do that. otherwise it wouldn't hurt to use either one all year long. if you go synthetic, you can go longer between Oil Change Intervals and it'd be a lot easier to just stick with one grade of oil.
also, heavier weight is usually for cars that either travel at really high speeds alot or cars/trucks that go through a lot of load (on the engine) like towing for example.
just my opinion.
Old 07-08-08, 04:18 PM
Bichon
Super Moderator
Bichon's Avatar
5w-20 and 5w-30 are both recommended by Lexus for year round use. 5w-20 is factory fill and endorsed in this TSIB:
Old 07-08-08, 06:41 PM
XhyDra
XhyDra's Avatar
Yeah it was weird, I got my oil change then I reset my ECU so it could re-learn the way I drive, and also so it can pick up my F-Sport Intake better. My rpms seemed different than the last time I did an oil change at the dealership & they were lower at cruising speeds ex 60mph I was at 1.7k on the rpms, and at 40mph it stayed at about 1.3k on both 5th & 6th gear. The car seems to idle nicer too :]
Old 07-08-08, 10:01 PM
chickenass
chickenass's Avatar
Do u guys happen to knwo which filter i should use for Mobil 1 Extended Performance because Lexus told me to buy their filter... and btw how do you reset ur ECU i would like to reset mine after i do my oil change and with my F-Sport Intake.
Old 07-08-08, 10:42 PM
eric_r_ho
eric_r_ho's Avatar
ALways use a factory OEM filter..nothing else. Reset by pulling the fuse for the ECU. MAKE SURE YOUR KEY IS NOT IN IGNITION OR ANYTHING OF THE SORT or you could fry your ME. or rather ECU.
Old 07-09-08, 12:43 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
5w20....or try 0w30 if you encounter extreme temp
https://www.clublexus.com/forums/sho...d.php?t=345510
Old 07-09-08, 09:47 AM
Kurtz
Kurtz's Avatar
What key?
Old 07-11-08, 02:15 AM
chickenass
chickenass's Avatar
hey is the ECU fuse located in the rectangular fuse box next to the battery? If so how do i remove the clear plastic box covering the middle fuses? And what would i use to remove and insert the fuse back? Plz help
Quick Reply: Oil Help
