Quick F-Sport rim question
yes they will work, however, i recommend you getting two sets of front rims and tires. that way you'll have the same rolling diamater and width all around. You can run a staggered setup too if you like as all four rims are 19" but you'd have the make sure all four tires are the same diameter. Though either way I recommend you not to as AWD systems don't work too well with them. Not saying they don't work though. Also if you have 4 sets that are the same, you can always do a tire rotation to keep the tires longer.
and i believe the offset will work just fine but as said before, you should check on that. you can bring into a local aftermarket store or local reputable shop to have them look at it for you. My local tuner shop has a complete guideline of what fits on what car.
