Yellow fog overlay help
Old 07-17-08, 11:24 PM
venZon
venZon's Avatar
Default Yellow fog overlay help
Well I got my car so time to put on some stuff. I order yellow fog overlays and red tailing overlays through Rvinly.
As I went to apply the yellow fogs I noticed there are tabs on each side?
How did everyone apply yours????
Take off front bumper?
does the black piece pop out beside the fog?
Cut the excess tabs off the vinyl shape?
Any tips would be great.
Thanks
Old 07-18-08, 03:53 AM
808Lexy
808Lexy's Avatar
why the hell do you need to take off the front bumper, you don't need to take off anything. don't do that.mines didn't come w/ a tab. but i guess just cut it off. make sure u keep it moist then dry it up. it only took me 15 minutes for both real simple. you don't need any ratchet or screws.
Old 07-18-08, 05:10 AM
Evitzee
Evitzee's Avatar
Tab is there to hold onto while initially applying it to the lens. You can cut it off beforehand if you want, but it is not necessary. Once the overlay is applied just use a bit of stiff cardboard (or credit card) to push the tab between the lens and the bumper. No fuss, no muss. No need to remove anything.
Old 07-18-08, 05:48 AM
venZon
venZon's Avatar
ok just kind of got confused about the tabs.
Thanks guys
Old 07-18-08, 06:21 AM
DRivera250
DRivera250's Avatar
the fogs are harder to apply then the red outs. But one thing I noticed about the fog overlay that its is very forgiving. You can pull and reapply. I actually messed mine up too many folds. I need to order some more.
Old 07-18-08, 06:38 AM
Brian231
Brian231's Avatar
The fogs are a bit harder to apply. Make sure you clean the fog lens with rubbing alcohol. The fog vinyl thata is the thicker "protective" film, is a bit trickier to instal.
Old 07-18-08, 07:14 AM
venZon
venZon's Avatar
would applying it wet help? heat gun?
I don't apply vinly too often and don't want to mess up
Old 07-18-08, 07:15 AM
Brian231
Brian231's Avatar
Applying it with a hair dryer/heat gun is smart, makes the vinyl more tacky and easier to manipulate.
Old 07-18-08, 07:26 AM
venZon
venZon's Avatar
Cool thanks for the tips. I'll do it after work today
Old 07-18-08, 07:34 AM
Brian231
Brian231's Avatar
One last thing, make sure the ambient temp is warm out.
Old 07-18-08, 08:13 AM
passnu2
passnu2's Avatar
Yes the Hair Dryer works perfect. I used it for the tails and the reflectors and it does work miracles. I havent had any issues with mine for some time now and it was the middle of winter when I put them on
Old 07-18-08, 08:32 AM
MLIAISON
MLIAISON's Avatar
Well mike, we're all glad that you didnt have a problem.......but this thread is about the OP not you LMAO!!! jk
Old 07-18-08, 10:48 AM
Brian231
Brian231's Avatar
Richie,
There is no "I" in TEAM!!! My point is, I have a gambling problem.
Old 07-18-08, 01:25 PM
jazba
jazba's Avatar
Is Rvinly a CL member or a website? How do they look? I need to get some yellow overlays myself
Old 07-18-08, 01:30 PM
venZon
venZon's Avatar
http://www.rvinyl.com/
Quick Reply: Yellow fog overlay help
