Drop in MPG all of a sudden....
Old 07-18-08, 11:21 AM
nabbun
nabbun's Avatar
damn ethanol and find out what oil they used in your oil change. maybe they didn't add enough?
Old 07-18-08, 12:16 PM
XhyDra
XhyDra's Avatar
It could be one of many things, the gas you're using, the oil that they put in your car, did you go to the same place for your oil change? I recently got an oil change, had them use my own oil Royal Purple 5W-20, my MPG are good in the city I'm doing 26 and highway 35. Also you might want to try re-setting your ECU and don't gas it like crazy. Just smooth. Also gasoline may be playing a bif role, when I use Shell my gas barely lasts me at all, I stick to 76 & Chevron 91 Premium.
Hope you get it figured out
Old 07-18-08, 02:39 PM
BoOst3d
BoOst3d's Avatar
if u pump gas with ethanol than you will get less gas mileage. the only gas i pump now is cheveron
Old 07-18-08, 08:37 PM
widebandph
widebandph's Avatar
Most likely it's your oil level being too high. Make sure the oil level is in the middle on the dipstick. Too much oil = lower mpg.
Old 07-18-08, 10:22 PM
jackblack7
jackblack7's Avatar
I had never heard that before, but a little research and you appear to be right. I just drained a little oil from my car because I had overfilled it when I changed my oil. It was high on the dipstick a couple of millimeters, so I don't know what that translates into but I drained quite a bit of oil to bring the level down. My MPG had gotten worse lately, so hopefully this will help.
Old 07-18-08, 11:19 PM
gocubs08
gocubs08's Avatar
Are you using the AC more? Try resetting your ECU, unplug the battery for 10 mins and then see where your at
I had the same issue once with my 250, i was getting 27-28 with combined 50/50 highway city driving on a tank, then all of a sudden i filled up and was only getting 23-24 driving the same routes.. so I unplugged my battery and checked my tires and then my next tank went up to 27 again.. wierd
Old 07-19-08, 01:52 AM
sincityIS
sincityIS's Avatar
All I use is Chevron as well, but I think even they use up to 10% ethanol. I didn't know there was any way around it anymore.
Old 07-22-08, 11:19 AM
JOEVFL
JOEVFL's Avatar
thanks guys, I'll be tryin all of these recommendations this week...
Old 07-22-08, 11:31 AM
llamaboiz
llamaboiz's Avatar
well maybe you ate too much hotdogs on the 4th and you've put on a few pounds
Old 07-22-08, 11:46 AM
Evil Teo
Evil Teo's Avatar
check your airfilter too.
Old 07-22-08, 12:46 PM
trdsw20
trdsw20's Avatar
when reset the ECU all we do is remove the negative on the battery? also do we need to reprogram anything? keys? window? or? how long is the wait to connect it back?
Old 07-22-08, 09:35 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,034 Likes on 2,445 Posts
Disconnecting the battery to reset the ECM is dumb. You lose everything.
From the FAQ stickied near the top of this forum:
https://www.clublexus.com/forums/sho...16&postcount=5
renovatior
NX - 1st Gen (2015-2021)
25
12-29-20 10:01 AM
2014GS350F
02-08-15 05:08 PM
markwill12
Hybrid Technology
99
03-31-14 04:27 PM
jimbo409
Hybrid Technology
06-26-12 08:07 AM
LBCDan
07-09-10 07:48 PM
Quick Reply: Drop in MPG all of a sudden....
