08 RV mirror, brake dust problem
At first when I went to the stealership to get the Rear view mirror changed they said that my VIN wasn't in range. After going there 3 in one month they finally changed my mirror ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I also got my brakes done on my 5k service with not problems.
something to keep in mind, the updated rearview mirror still vibrates somewhat.
i think the ones that are actually defective, display some play in the actual balljoint at the base of the mirror mount.
maybe take a look at ur mirror and see if the joint is solid?
in the case of mine, the mount to the windshield was loose, and the joint also exibihited a good amount of side to side play. new one is solid as far as that, but still vibrates a bit when u turn up the bass and waht not.
DrGP
08-18-13 10:56 AM
DrGP
06-11-08 05:08 PM
