TOM'S Linear Throttle System "L.T.S."
#31
I'm understanding this a little different than you. Linear controller = more linear match. If you take it from the title of the product then this device helps match the speed of the pedal to the speed of the throttle plate. The IS has a programed throttle speed. It doesn't matter how fast you move your foot the throttle plate still only moves at that same rate. This device changes the rate (speed) of the throttle plate to be more linear to the speed of the pedal. I don't think any company would change the feature you speak of. Example: 75% pedal = 75% open throttle plate. This LTS changes the speed in which 75% pedal = 75% throttle.
#32
It goes in-line on the wire connected to the gas pedal.
So the -only- thing it is capable of changing is the signal that tells the car how far you pressed the gas pedal.
So you can accomplish the same result, free, by pressing harder on the pedal.
#33
The install is just PnP. The wire harness from the pedal is unplugged. It it then plugged into the LTS piggy back. The other harness on the LTS is plugged into the pedal. Now you route the wiring for the controller to somewhere good (glove box, center console box) and you're set. The only panel you have to remove for a quicky install is the one above the pedals.
It's just lying to the ECU about how far you pressed the gas pedal.
#35
Bringing this back from the dead...
So since the last post on this thread about 7 months ago, has anyone actually installed this product to test its effectiveness? I'm very interested in it, but I would like to get more solid (not speculative) feedback from someone who has actually tried it.
#36
Tom's linear throttle control
where can i get one im have trouble looking for it
and im newb here oin the forms
Need a smog Check come by and we can make it go thru
allen smog test & repair
344 e foothill blvd
pomona ca 91767
look us up on yelp
344 e foothill blvd
pomona ca 91767
look us up on yelp
PNice972
06-28-18 01:38 PM
