About to Bring My IS350 in for 10K Service
you should just go in for an oil change service.. don't let them rob you of you rmoney.. its just a oil change and tire pressures.. you can inspect everything else yourself. i work at lexus and thats all it is.. im about 15 mins away from getting out of here.. but hey if you want to spend 110 bucks for an oil change you're entitled to the name baller lol
10000 MI or 16000 KM
Diagnose/Test
Vehicle Notes
Road-test vehicle.
Inspect
Air Filter Element
Required only if vehicle is operated primarily in desert, on dirt roads or while towing.
Ball Joint Notes
Body and Frame (Nuts and bolts on chassis.)
Brakes and Traction Control
Measure thickness of front brake pads and rotors. Visually inspect brake pads/discs.
Constant Velocity Joint Boot
Steering
Steering linkage and boots. Required only if vehicle is operated primarily in desert, on dirt roads or while towing.
Replace
Cabin Air Filter
Engine Oil
Oil Filter, Engine
Reset
Oil Change Reminder Lamp (If equipped.)
Rotate
Tires (Except IS with different sized front and rear tires.)
Tighten/Torque
Axle Shaft Notes
Re-torque drive shaft flange bolts. Required only if vehicle is operated primarily in desert, on dirt roads or while towing.
Seems like an oil change to me....
If you want the meat and potatos of it
Diagnose/Test
Vehicle Notes
Road-test vehicle.
Inspect
Air Filter Element
Ball Joint Notes
Steering
Replace
Cabin Air Filter
Engine Oil
Oil Filter, Engine
Reset
Rotate
Tighten/Torque
Axle Shaft Notes
My 10k cost me 7 quarts of Amsoil and $20 in labor including the oil filter from an indy shop. No problems thru 17k miles except musky a/c odor. Don't waste your hard earned $$$.
If it is just an oil change and I go to an independent Oil Change facility other than the Lexus dealership, that shouldn't affect my warranty right? Are there any problems I should worry about in case I need to bring the 2IS for service at the Lexus dealership later on?
