Help ... any threads to show rear gfx kit install w/ just tape?
Yup here's another thread on gfx kits.
Well, I was planning to get the rear gfx kit for the rear bumper. I know this part requires the drilling but I also know that some here have also used the tape method only. I have searched but can not find any threads about how to use only the tape method. Are there any DIYs with that? Also, which and where to get the tape? Are there any cons to using the tape method besides possible loss of kit on the highway somewhere
? hah that itself should be the main con right.. anyways ... can anybody help? thanks
Thanks for the heads up. I could have sworn someone did it for the 2IS. I thought I had mistaken it for people with the 1IS with their kits. I'll give the search another shot.
So all you used was the tape supplied and nothing else, eh? Did you just snap off the tabs? How long have to had it on? Not quite sure where you are located but does the hot weather affect the adhesion/movement of the rear bumper kit? Did you have to cut the bumper for exhaust opening? Do you have any pictures? Sorry for all the questions. Thanks
The easiest to put it on i foudn was to rest the lip on the original box it shipped in and slowly slip the lip on. that way if you get one side fitted perfectly, the other side wont fall off while you are test fitting it.
tracerit
10-12-08 11:19 PM
