My headlight went out so i went and check....
Old 08-06-08, 05:32 PM
TLe2006
TLe2006's Avatar
Default My headlight went out so i went and check....
Look at this!!
[IMG][/IMG]
Old 08-06-08, 05:58 PM
Hartawan
Former Vendor
Hartawan's Avatar
Oh jeez how does t hat happen...
Old 08-06-08, 06:01 PM
iSuxeL
iSuxeL's Avatar
Holy shish kabob! Good thing that's covered under warranty.
Old 08-06-08, 06:03 PM
Reyngel
Reyngel's Avatar
Did you drop it after you took the bulb out or something? I don't see how that could happen just sitting in the housing?
Old 08-06-08, 06:10 PM
RshaoKh
RshaoKh's Avatar
Is that an OEM bulb or is that an aftermarket one?
Old 08-06-08, 06:16 PM
TLe2006
TLe2006's Avatar
I didn't drop it after i took it out and it's a stock bulb. I raised my headlight and i think that might be the cause of it because of the angle.
i doubt it'll be cover under warranty. They'll probably blame on me thinking i dropped it. It did really look like that after i took it out.
Old 08-06-08, 06:23 PM
iSuxeL
iSuxeL's Avatar
Put it back in and go to the dealer, they should cover it.
Old 08-06-08, 08:32 PM
sinister2c
sinister2c's Avatar
yea leave it in and bring it in....its a warranty item. unless you want to spend like $100 to replace it on your own.
Old 08-06-08, 08:51 PM
TLe2006
TLe2006's Avatar
i already bought one bulb from passnu2. i doubt they'll replace it w/out giving me a hard time and might break something while they're at it.
Old 08-06-08, 10:23 PM
hihi410
hihi410's Avatar
I haven't really seen a bulb snap in 1/2, usually just the fuse that goes out. Maybe its a defect item or something.
Only thing i can think of would be the bulb hitting some object or there was a super burst of heat which melted down the bulb cyclops style.
Old 08-06-08, 10:27 PM
kuuqi
kuuqi's Avatar
wow that's crazy.
well at least d4s bulbs are completely mercury free unlike older HID bulbs so now you won't go crazy like the mad hatter
Old 08-06-08, 10:31 PM
file82
file82's Avatar
oh i should ask you guys before i spent $100 on the bulb...
didnt know it is covered by warrenty
Old 08-06-08, 10:51 PM
eric_r_ho
eric_r_ho's Avatar
The only way that could've happened was whoever put taht bulb in, touched it w/ their hands, their oil-infested hands..
Old 08-06-08, 10:56 PM
ELL Y
ELL Y's Avatar
sweet
is that like, the new technology or something?
Old 08-07-08, 12:14 AM
IS-MIKE
IS-MIKE's Avatar
I think the bulb might be a quartz envelope yeah it could have been oil from handling on the bulb that weakened the quartz causing the failure. Another way the bulb could explode like that is if water somehow spilled on the hot bulb but thats not likely if the headlight isn't leaking. Most likely it was oil from handling.
Quick Reply: My headlight went out so i went and check....
