wheel fitment??
Just wondering would these fit on a IS250 without some rubbing issue?? Because i think the 25 offset is a little bit kind of stretch for a IS. Thank you.
20x8 Front ET25 2.5"
20x10 Rear ET35 4" Lip
the fronts should be fine. but only when you are at full turning lock, it might rub.
the rears will definitely rub if you're running a 10" rear with +35 offset.
also depends on your tires sizes. if you dont want to rub with the 10" in the rear, i suggest you run a 265 or even a 255 35 tire.
for the fronts, a 225 or 235 35 would be fine.
i2fat
06-23-15 10:35 AM
is250rida
11-01-08 01:29 AM
