Official "Got my GFX kit" thread
#46
very nice. I ordered my starfire gfx kit at 12:01 and have not recieved a tracking number or a call saying that I missed the boat. I called on thursday and Darrell told me the workorder was at the warehouse being completed, but haven't heard since. I guess 'll be getting a call shortly saying i'm SOL
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#47
Summary of instructions:
1. Removed 2 clips from rear mudflap. Twist mudflap away (Can't be removed).
2. Remove each screw on the ends in the wheel wells.
3. Remove all 7 tabs by pulling the top tab and then pulling off the whole clip.
4. Remove 2 screws behind weather stripping on the sill. The front screw is located directly under the door hinge. Pull the weather stripping away and stick a screw driver in. The rear screw is easier to get to. It's near the end of the weather stripping.
5. Gently pull the side skirt off. I started from the front and worked my way to the rear. There are 10 or so clips holding to the car so you have to pull with enough force to undo them. Don't pull too hard or you can damage the parts.
6. Install new side skirt. I started from the rear and pushed it in making sure the clips "clicked".
7. Screw in the ends and then screw in the sills.
8. Add the 7 clips.
9. Swap the weather stripping. Make sure all of the clips click.
10. Done.
#51
Ordered front lip early Weds. morning, arrived on Friday, installed Saturday morning. Thanks Sewell!!!
Very easy install. Be sure all the clips are in all the way -- I wasn't happy with the way it looked and then I found this thread.
https://www.clublexus.com/forums/sho...&highlight=lip
So I took off the lip and made sure the clips "clicked" in. No gaps...
#52
So I took off the lip and made sure the clips "clicked" in. No gaps...![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#53
*sigh ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
i tried install the front lip today and got frustrated. turns out when i had the front bumper replaced by the insurance company's repair shop they only put 5 of the screws instead of 9 and didn't use the proper clip for one of the clips and now there is gap between the headlight and bumper. I won't be able to install the lip without breaking clip.
maybe i'll just call the dealer.
#54
You can adjust the gap between the headlight and bumper. This is a common fix.
#56
but i put my front lip and side on, no drilling for the front lip just ripped those tabs off, i got a slight 1mm gap if that on the left hand side of the car but other then that perfect....my paint is a little off compared to the lip now, just because of all the road rash on my nose.
#58
yea i need to know this also..
#59
one corner of my side skirt though has the paint worn off, didn't notice it until it was on the car. must have been form the shipping. but i need to go get some touch up paint anyways so it'll be alright.
#60
