Rear GFX lip installed without screw or cutting bumper
Old 07-14-11, 09:35 PM
  #91
allst4r
allst4r's Avatar
can you take a picture of the screw u put in???? u put them on the bottem sides or in the middel between the exhaust. ???
Old 09-16-11, 03:29 PM
  #92
allst4r
allst4r's Avatar
newb here needs help..got these pics off page 4... do i cut off all the tabs? what about thoes plastic bumps in the bottem of the rear lip gfx kit? do i dremel thoes off? or leave it. cant really tell in this pic just anticipating what i need to do when my rear lip gets here.
Attached Thumbnails Rear GFX lip installed without screw or cutting bumper-picture023-vi.jpg
Old 09-16-11, 03:37 PM
  #93
MrBBQ
MrBBQ's Avatar
No, do not cut those off. Just rip off the metal mounting tabs (they're held on double sided tape) and shave the pointy alignment nub on the upper middle portion of the inner lip. Basically you will be removing the mounting parts that are meant to penetrate the bumper. Those tabs you circled sit against the bumper so no don't cut them off.
Old 09-16-11, 04:44 PM
  #94
santacruz
santacruz's Avatar
Here's my thought on it...if the metal mounting tabs are held onto the lip with 3m tape...whats the difference if you just attach the lip with 3m tape? Your bond is only as strong as your weakest link right? If the 3m is going to fail it's going to fail no matter what it's application method is.
Old 09-17-11, 01:05 AM
  #95
omgitsjoe
omgitsjoe's Avatar
I was on the border line on whether or not to get the gfx lip but didnt want the pain of going to a shop and getting it installed then i see this thread now i'm sooo tempted to get this since i have a lot of confidence with these 3m tapes ! Oh oh im going to be in trouble with the Mrs .... again
Old 11-14-11, 08:40 PM
  #96
10lexISR6
10lexISR6's Avatar
this is kind of a late post in that i installed my rear lip several weeks via this method. It works fine. it was a little trickier than the cut method i did on my 2010 obsidian, IMO the cut method fit better of course but this way is much easier and reversible. im pleased.
this WAS my 2010 obsidian i did the cut method on vs. my 2011 tungsten no cut method.
Old 11-14-11, 10:05 PM
  #97
istundra
istundra's Avatar
for the back... CUT IT OUT!!!!
You'll have problems in the exhaust outlet. it will not fit right. try it and you will see!
plus. when you do it this way, i don't think you have any way to mount it. so a very big risk it'll fall off!!!
Old 11-15-11, 12:56 AM
  #98
MrBBQ
MrBBQ's Avatar
^^ It does fit if you squeeze the GFX lip exhaust cutout and push it in. It's only slightly bigger.
Old 11-15-11, 05:42 AM
  #99
chikoo
chikoo's Avatar
Originally Posted by Clark Kent
Wow. That looks really good. Has anyone else done this? I wonder how it holds up over time, rain, and snow?
3M automotive black tape is awesome and actually gets stronger over time making it impossible to even take it off without damaging the paint.
Old 11-15-11, 08:29 AM
  #100
MrBBQ
MrBBQ's Avatar
Yea, 3M double sided tape is the shiznit. I love this stuff so much I bought 36 yards x 0.6" of 3M VHB tape for $27 shipped (eBay). VHB (Very High Bond) is crazy strong. I installed my rear lip and my roof spoiler and haven't even used up half.
Old 11-15-11, 04:34 PM
  #101
chikoo
chikoo's Avatar
This is what I m talking about.
3M Automotive Acrylic Plus Attachment Tape - 1/4in. x 20 Yard Roll Model 06386 : 3M Automotive Adhesive acrylic foam tape
http://www.amazon.com/gp/aw/d/B000P1...w_d_iv_hi?is=l
Old 11-15-11, 05:04 PM
  #102
KillaIS250
KillaIS250's Avatar
I need to redo mine, the area around the curves has come off
Old 11-23-11, 06:00 PM
  #103
langjaykev
langjaykev's Avatar
i just tried this. now im super depressed..
Old 11-23-11, 06:29 PM
  #104
HeartmyIS
HeartmyIS's Avatar
^ someone mentioned above about squeezing the GFX lip exhaust area so it fits into the stock exhaust area, I think I will try that this week.
Old 11-23-11, 09:39 PM
  #105
Wunko
Wunko's Avatar
Hmm... What exactly happened that made you super depressed? Did it not go on correctly or did you make a mistake on something?
Quick Reply: Rear GFX lip installed without screw or cutting bumper
